Old 02-10-2015, 07:41 PM   #1
Jferrante
Jferrante's Avatar
327 Motor Coming out what else to replace?
So I am planning on taking my the motor out of my 64 C10 in the next month or so since I have some leaks from the rear main seal as well as timing chain cover. I am putting a list together of items to replace while this is happening and would love to hear any other suggestions for parts to replace or best place to source some decent fitting parts.
Here is the list I put together so far.
Oil Pan and gasket
Timing Cover and Gasket
Front Main Seal
Water Pump Gasket
Possible new timing chain???
Thanks for the input...also I did a search but didnt see anything so point me there if this has already been discussed.
Thanks again
Jferrante is offline   Reply With Quote
Old 02-10-2015, 10:56 PM   #2
donthekawguy
donthekawguy's Avatar
Re: 327 Motor Coming out what else to replace?
I would do the freeze plugs also. Having replaced them once in my 69 firebird while the motor was in was not fun.
66 shorty
donthekawguy is offline   Reply With Quote
Old 02-11-2015, 01:30 AM   #3
Captainfab
60-66 Nut
Definitely replace the timing chain, and I would also replace the oil pump and pickup screen.
Old 02-11-2015, 10:15 AM   #4
Lokin4AReason
Lokin4AReason's Avatar
also prime the oil pump before installing it ...
dont want to hear excuses, i want to hear solution(s)
Lokin4AReason is offline   Reply With Quote
Old 02-11-2015, 12:43 PM   #5
Chevy Fleetside
Chevy Fleetside's Avatar
I would get a full gasket set and just do the whole thing. $41 at summit if I remember right . I just got one for my 283. I would hate to pull the engine and then have a head gasket blow.. That would blow..
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 02-11-2015, 01:53 PM   #6
Mackie
Mackie's Avatar
I thought this was going to be a question about what other engine to put in instead...like big block, LS, etc..
Depending on the mileage and condition it might be the time (while it's out) to do a total refresh with rings, bearings and heads reconned. Keep the 327, for sure.
Mackie is offline   Reply With Quote
Old 02-11-2015, 01:56 PM   #7
vince1
I'd check compression first. If still good then slide in some bearings when the pan is off as well as what already has been mentioned. If compression is low do the full rebuild.
vince1 is offline   Reply With Quote
Old 02-11-2015, 02:51 PM   #8
Jferrante
Jferrante's Avatar
All great responses - I am definitely keeping the 327 since the block looks to be healthy; I am just getting some rear main leaks and figured its worth taking it down before summer and replacing some things that will make it reliable for years to come.
Old 02-12-2015, 11:25 AM   #9
jchav62
1962 C-10
jchav62's Avatar
I would also drill and tap the crank snout so you can bolt on the harmonic balancer.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 02-12-2015, 05:01 PM   #10
duallyjams
duallyjams's Avatar
replace the valve seals on the heads.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
