Old 02-11-2015, 09:58 PM   #1
Nicks67C10
Trans linkage questions
I am doing an Ls swap in my 67 C10, looking to put a 4L80 in. I am not sure how to build the shift linkage for a column shift to the trans. Has anyone made their own or know of a good kit?
Nicks67C10 is offline   Reply With Quote
Old 02-11-2015, 10:21 PM   #2
GryGhost
GryGhost's Avatar
Re: Trans linkage questions
If you can use a rod style linkage, the kit I got from LMC worked really well. Clean looking setup to... There was some custom bends and trimming but nothing major. It went from the column strait to the trans linkage (TH350)and bypassed the factory on frame stuff.
1970 c10 lwb mild 355/TH350 w 3.73 gears...lowered 3/3 with 275/60s went 9.98 on 1/8th mile, gota get better than that!
GryGhost is offline   Reply With Quote
Old 02-11-2015, 10:23 PM   #3
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Post this question in the engine and drivetrain section. There is also a subforum there for LS based swaps with late model trasmissions.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 02-12-2015, 12:01 AM   #4
72MARIO
72MARIO's Avatar
Lokar makes a gm kit thats a custom fit.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 02-12-2015, 12:02 AM   #5
72MARIO
72MARIO's Avatar
http://www.lokar.com/product-pgs/col...shiftlink.html
2005 TAHOE DD
Old 02-12-2015, 02:24 AM   #6
Longhorn 70
Longhorn 70's Avatar
I have the Lokar kit on my 700R4. Works well, easy to install. I did have to make a slight bend in the rod to make it clear the headers.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 02-12-2015, 02:26 AM   #7
leddzepp
Moderator
leddzepp's Avatar
Use Lokar or Kugel Komponents linkage. Adapts to any GM transmission.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 02-18-2015, 11:57 PM   #8
sixty-eight shorty
sixty-eight shorty's Avatar
I used my original transmission linkage from my 71 blazer .
sixty-eight shorty is offline   Reply With Quote
