Old 02-13-2015, 02:37 AM   #1
SickAss 62 C10
SickAss 62 C10's Avatar
Help me figure it out
Hey brothers I've recently picked up a 1962 C10 the previous owner told me it had a pontiac 400 motor and didn't mention what transmission it has. So my question is Can anyone help me figure out what I have in my truck.
SickAss 62 C10 is offline   Reply With Quote
Old 02-13-2015, 04:08 AM   #2
SickAss 62 C10
Old 02-13-2015, 04:34 AM   #3
1971 GMC SHORTY
1971 GMC SHORTY's Avatar
Re: Help me figure it out
Take a Picture
1966 GMC K25 V6 351E Original Utility Truck
2000 C3500 Hot Rod Utility Truck
2003 ROAD KING 100th 124ci 6 Speed
145CI M/P Pro Street FXR
2002 FXDP
2007 2500HD DURAMAX. DD
Studio Teamsters / Mechanic
Retired GM Master Tech 20 Years
Retired Ford Tech 15 Years
1971 GMC SHORTY is offline   Reply With Quote
Old 02-13-2015, 05:07 AM   #4
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Arrow Re: Help me figure it out
Is it manual or Automatic? What are the numbers on the trans? Pictures?
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 02-13-2015, 07:29 AM   #5
PGSigns
PGSigns's Avatar
If it is an automatic there are lots of places on the net that have the layout of the pan and you just match the drawing to your trans. If it is a manual more ino and a picture would be a big help.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 02-13-2015, 05:05 PM   #6
awbrown
I can ,all we need is some pictures .... Pics of the trans pan and pictures of the engine would be sufficient ...
awbrown is offline   Reply With Quote
Old 02-13-2015, 05:19 PM   #7
SickAss 62 C10
Trying to get pics posted so please Bear with me
Old 02-13-2015, 05:21 PM   #8
SickAss 62 C10
Here's another I don't know why there not right side up
Old 02-13-2015, 06:16 PM   #9
Fixed your pictures
Pontiac blocks can be anything from a 350 to a 455 depending on the year. MY guess is you got a 389 or 400. Far as the automatic, it is probably be be pontiac's version of the Turbo-400
Best bet is to get the numbers off the block and check them on the web and same for the tranny, or at least a photo of the tranny side and pan.
Old 02-13-2015, 06:52 PM   #10
awbrown
On the drivers side of the block by the engine mount there is a number cast into the block ... not all of them had it .. that will be the engine size .. not all of them had it though ..also , do you have a pick of the trans pan??? You do have a pontiac though...
Old 02-13-2015, 07:23 PM   #11
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
On my Chevy block, there is an area on the passenger side head surface area that sticks out with numbers stamped in it. From that code I was able to figure out what engine I had. I was told I had a 350CI, not so, it turned out to be a 305.
Check out a site like this..
http://www.pontiacstreetperformance....p/blockID.html
or
http://www.teufert.net/identify/identify.htm
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 02-14-2015, 01:09 AM   #12
SickAss 62 C10
Size:  45.7 KBHere are a couple of pics of the tranny
Old 02-14-2015, 01:11 AM   #13
SickAss 62 C10
Size:  29.2 KBAnother pic sorry it's blurry but it says Hydra-Matic doc. of GMC
Old 02-14-2015, 01:31 AM   #14
AzCountryman
AzCountryman's Avatar
lol you have a Hydramatic.....that was easy.
Are you a collector? If so come check out Collectorsunleashed.com Doesnt matter what it is we have a spot to show it off.
http://www.collectorsunleashed.com/#
AzCountryman is offline   Reply With Quote
Old 02-14-2015, 01:37 AM   #15
SickAss 62 C10
heres a pic of the truck
Old 02-14-2015, 02:05 AM   #16
frankslagoon
TH 400 Tranny . Probably paired with one of the the bigger motors from the factory
frankslagoon is offline   Reply With Quote
Old 02-14-2015, 09:23 AM   #17
Truck looks good. yes, you have a T400 tranny and I have always like the Pontiac motors. Looks like you got a sweet ride.
Old 02-14-2015, 11:56 AM   #18
63sbssbbw
UCA63
63sbssbbw's Avatar
Sweet, I'd love to have poncho in mine!
Keep in mind that Buick/Olds/Pontiacs are not chevy's
Externally they look the same
But they rotate in the opposite direction
T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 02-14-2015, 02:46 PM   #19
frankslagoon
T
Hmmm. I thought they all rotate clockwise ?
Old 02-14-2015, 03:28 PM   #20
63sbssbbw
UCA63
63sbssbbw's Avatar
My apologies Frank you are correct
Sorry Sick ass
Engaged my mouth before my brain was in gear
T
member#7816
'61 GMC in progress
Old 02-14-2015, 07:05 PM   #21
frankslagoon
Ha I do it to. if the motors turned the other way we would have 3 speeds in reverse but a hell of hole shot in first ha ha. On the old direct reversible diesels we could bring to stop and then slide the camshaft to reverse lobes and when ya started it again it would run backwards.
Old 02-14-2015, 08:14 PM   #22
SickAss 62 C10
Thanks guys for all the compliments and advice it helped out a lot. I found a 350 stamp on the drivers side of the block and the P.O did mention he bored it out.How do i find out who made the engine should that be stamped also? 63sbssbbw mouth out runs my brain ALL the time. hey what is ''pancho''?
Old 02-15-2015, 10:41 AM   #23
63sbssbbw
UCA63
63sbssbbw's Avatar
Thanks guys for not flaming me! LOL
Poncho is a slang term for Pontiac (he was an indian chief),Also , I believe Pontiac Michigan was named after the same guy.
Absolutely love that color,,Sweet lookin' truck.
T
member#7816
'61 GMC in progress
Old 02-15-2015, 02:05 PM   #24
61K10
61K10's Avatar
nice tk SA--Pontiac eng. is a nice alternative to the norm. Have fun-------
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 02-16-2015, 04:31 PM   #25
awbrown
I have the same engine in my Lemans .. if it runs and moves you are all set !!!
