Old 02-15-2015, 01:21 AM   #1
iluvmy72
interchanging and matching 97 & 96 tranny's
I know there is a ton of info out there on the web AND SHOPS but wherever I look, I find a different opinion that tries to sound official and it contradicts what others are saying. For example one place says a 97 4l60e 4dw tranny from a suburban is a direct swap for a 96 and vice verse. But a 97 tranny from a pickup they say will not fit in a 96 burb. I am thinking of upgrading to a 4l80e and my cousin is offering to by the 4l60e off of me but will it fit in his 97 1500 truck? Are the input shafts the same? Are the bell housings the same between the 96 & 97 years? Do the transfer cases mount the same? Are the pin connectors the same? Does the PCM need to be reprogrammed?
iluvmy72 is offline   Reply With Quote
Old 02-15-2015, 08:08 AM   #2
BigBlocksRule
Re: interchanging and matching 97 & 96 tranny's
PCM will likely need a reprogram.
Physically, they'll fit. Input and output shafts are the same size.
The 4L80E changed coolant line connections right about that time, that might be a stumbling block for you, but not for him since 4L60E's kept the lines in the same spot.
BigBlocksRule is offline   Reply With Quote
Old 02-15-2015, 11:19 AM   #3
iluvmy72
I know mine will need to be reprogrammed. But what about my cousin's? His is 4l60- 4l60 just different years.
Old 02-17-2015, 10:00 AM   #4
iluvmy72
no one?
Old 02-17-2015, 10:36 AM   #5
95 S_Trucker
95 S_Trucker's Avatar
I am fairly sure that 96 and early 97(1 piece case) are interchangeable. That's 4l60e. Id shoot a pm to clinebarger.
He is the auto trans expert around here.
http://67-72chevytrucks.com/vboard/member.php?u=57654
95 S_Trucker is offline   Reply With Quote
