Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 02-16-2015, 01:26 PM   #1
cru_zn_29
cru_zn_29's Avatar
Wanted L/B Trim 63/66
Looking for 1 Long Bed Molding 1 3/8" & 1 door Molding 1 3/8 wide. NOS or used that can be re anodized .
cru_zn_29 is offline   Reply With Quote
Old 02-16-2015, 04:35 PM   #2
60-66
60-66's Avatar
Re: Wanted L/B Trim 63/66
Just went through your album on your 65 C20 ! WOW! That is looking fantastic ! Very nice work.
https://67-72chevytrucks.com/vboard/...1966+gmc+panel
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 02-16-2015, 04:47 PM   #3
oem4me
oem4me's Avatar
Do you know of a place that will re-do the bright-dip to factory spec? For years there was a place in North Hollywood called Ano-brite that did this work, but they closed up awhile back.
Old 02-16-2015, 10:15 PM   #4
BLK65K10
Kenny I may have both pieces you need used.
BLK65K10 is offline   Reply With Quote
Old 02-16-2015, 11:23 PM   #5
cru_zn_29
cru_zn_29's Avatar
Lyle I pmed you
Old 02-16-2015, 11:33 PM   #6
cru_zn_29
cru_zn_29's Avatar
I haven't looked I wanted to locate the missing trim I need first.
Old 02-17-2015, 12:46 AM   #7
1960chevypanel
I have the upper bed piece in nice shape if you need it.
1960chevypanel is offline   Reply With Quote
Old 02-17-2015, 02:12 PM   #8
cru_zn_29
cru_zn_29's Avatar
do you have a picture?
Old 02-17-2015, 03:01 PM   #9
1960chevypanel
Please PM me your email and I'll get you some.
Old 02-17-2015, 05:16 PM   #10
cru_zn_29
cru_zn_29's Avatar
PM sent
Old 02-19-2015, 10:25 PM   #11
BLK65K10
I will have to pass on the trim it isn't quite good enough to restore.
Old 02-21-2015, 11:36 AM   #12
cru_zn_29
cru_zn_29's Avatar
ttt
Old 02-21-2015, 04:02 PM   #13
60-66
60-66's Avatar
So still nothing ? OK, I can help. I have one bed molding very straight just dull it should be fine for a reanodize core. Should have a door molding, will check.
Old 02-21-2015, 06:28 PM   #14
cru_zn_29
cru_zn_29's Avatar
Great that's what I am looking for.
Old 02-21-2015, 08:28 PM   #15
60-66
60-66's Avatar
First three are one of the door moldings, I have more so will look tomorrow, has a few dings. The bed molding has no dings and the only reason its dull is from that purple clean. Straight but just some little waves when you eye it up down the side, its the best used one I have.
Old 02-22-2015, 11:13 AM   #16
cru_zn_29
cru_zn_29's Avatar
That purple stuff is pretty strong. Its hard for me to see the waves you are seeing. What do you think caused the waves? The one deep dent in the door trim might be a hard one to repair or does the picture make it look worse than it is.
Old 02-22-2015, 02:23 PM   #17
60-66
60-66's Avatar
Hard to say , something leaning against it ? I have taken some NOS ones out of wrappers and seen similar waves . Its my opinion you should just try to find NOS if you want better than this . If your looking for arrow straight buy the ones in the paper wrappers for the best chance of getting a good one . The ones in the green rubber I've found to be pretty wavy. I just scored a bunch of the wide short bed upper moldings and they are super straight. A few guys criticized the fact that they had a web address on the label, I'll take those any time !!
Old 02-22-2015, 02:31 PM   #18
oem4me
oem4me's Avatar
I've done a little bit of trim straightening, and from my perspective the deep but localized dents are much easier to repair than general waviness. This type of repair does require refinishing, but if you were gonna do that anyway, who cares. just sayin.
Old 02-23-2015, 11:42 AM   #19
cru_zn_29
cru_zn_29's Avatar
I wish I could find a NOS. I am having my trim pieces striped and redone so I am looking for the best trim available to start with. PM sent
Old 03-09-2015, 11:15 PM   #20
cru_zn_29
cru_zn_29's Avatar
Jon
Received trim this afternoon looks great. Thanks Kenny
Old 03-10-2015, 11:59 AM   #21
60-66
60-66's Avatar
Great ! Hope it works for you. Came off a 28,000 mile truck. Keep us posted !
