Old 02-18-2015, 08:15 PM   #1
Evoracer
Another disc/wheel question
63 C10. Again, the ago old question... I want to run a front disc conversion WITH a stock steel 15" wheel. Disc conversion suppliers say no. Is it possible without finding some special year voodoo wheel? Is there a new steel wheel available? LCA mods?
I still haven't purchased a kit. 5 or 6 lug doesn't mat.ter at this point. Like the older steel wheel style, and I want to run dog dish cap.
Evoracer is offline   Reply With Quote
Old 02-18-2015, 08:24 PM   #2
sixTsix
Re: Another disc/wheel question
Wheel Vintique. They will have what ya need if your looking to run a steel OEM looking wheel
http://www.wheelvintiques.com/index.php/
If you must have stock, GM production wheel, find you a 71 chevy "4 nub wheel"
66' Short Stepper- 350-NP440/4speed
Under Construction - http://67-72chevytrucks.com/vboard/s...d.php?t=629426
sixTsix is offline   Reply With Quote
Old 02-18-2015, 11:15 PM   #3
HumphreyMurdoch
HumphreyMurdoch's Avatar
I'm in the midst of swapping in '79 C10 front suspension on my '62 and I'm going to run plain ol' 5 lug steel wheels. They clear everything just fine and I'v got drop spindles. The fronts are 15x6 and rears are 15x7 and I found them digging through a pile of wheels at the junk yard so I can't tell you what exactly they're from. also found couple that were on a truck still and the same dog dish caps I ran on my original 6 lug wheels fit on the new 5 lug Wheels.
But, 5x5 steel wheels are getting harder to find. That's a common trailer bolt pattern as well as 70's full size gms that are used for demo derbies. I used one I dug up in mud because it was all I could find.
'62 C10 LWB fleet side.
283 w/ a T5
HumphreyMurdoch is offline   Reply With Quote
Old 02-19-2015, 02:27 AM   #4
64chevtruck
Hi, What I just figured out is that if you have a stock steel rim, they will not clear the calipers, BUT I could run my partshouse chrome reverse rims (painted red in the pics) no problem, The reverse rims were only reversed about an inch compared to the stock steel ones but it made all the difference in clearance, I want to run the large dish caps and rings (painted black) so Ill just get some spacers in there to get the clearance,
Take care
Andy
64 C10 Fleetside LB 4 Sp/292 Build http://67-72chevytrucks.com/vboard/s...d.php?t=602438
70 GMC 1500 Fleetside LB 3OT/350 Build http://67-72chevytrucks.com/vboard/s...83#post6767983
76 GMC CCLB Dually Build http://67-72chevytrucks.com/vboard/s...d.php?t=691612
79 GMC 3500 Fleetside LB 454/400
90 Suburban Silverado 4x4 350/700R4
97 1500 Cheyenne Short Fleet 350/5sp
64chevtruck is offline   Reply With Quote
Old 02-19-2015, 10:37 AM   #5
theastronaut
theastronaut's Avatar
Try a 1/4" wheel spacer. Worked on my '66 with factory drum wheels and disc brakes.
theastronaut is offline   Reply With Quote
Old 02-19-2015, 11:05 AM   #6
64chevtruck
Hi Astronaut, Thanks for your input, I got aftermarket disk setup and must have a larger caliper than you ran, Because I tried to put some fat 1/4 inch thick washers on 3 of the lugs so I could just move the truck around in my shop and there was still not enough clearance, Then I got the angle grinder out and rounded the outer corner of the caliper. Still not enough clearance for some reason,
I was going to look for some 3/4 inch spacers if they make em.
Have a good weekend
Old 02-22-2015, 11:48 PM   #7
Evoracer
I went with the Wheel Vintique 62 series 15x6, and going 5 lug ECE. We'll see how it goes...
Old 02-23-2015, 10:49 AM   #8
chevyrestoguy
chevyrestoguy's Avatar
From my experience, stock 7" wide steel wheel will clear with stock spindles and a stock caliper. It will not clear with a drop spindle with over 2.5" drop. A 1/4" spacer will make it clear.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 02-23-2015, 02:31 PM   #9
OldGMJon
OldGMJon's Avatar
Cool Re: Another disc/wheel question
If you must have stock, GM production wheel, find you a 71 chevy "4 nub wheel"[/QUOTE]
I just picked up a pair of 71', 5", 6-lug nubbies that are disk brake ready.
The center lug part should stretch out at 90 degrees angles from the rim's center for caliper clearance,
where the non-disk brake wheels stretch at about a 45 degree angle from the rim if that makes sense.
Projects:
65' Chevy C10 swb (rebuilt chassis)
65' Chevy Panel swb
64' Chevy C30 flatbed "above" 80' C30 "beneath")
Parts:
66' GMC 2503 & 65' GMC I1500
OldGMJon is offline   Reply With Quote
Old 02-23-2015, 03:19 PM   #10
Chevy Fleetside
Chevy Fleetside's Avatar
If you go with Wheel Vintiques, try looking them up at Summit Racing. They usually sell them for less.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 02-23-2015, 03:28 PM   #11
Evoracer
Thanks. In fact, just received my Wheel Vintiques from Summit today!
