Old 02-19-2015, 08:53 PM   #1
SickAss 62 C10
SickAss 62 C10's Avatar
HELP!!! i can't stop!
So i installed new Master cylinder and wheel cylinders,Cleaned up all the adjusters and that stuff. Blew out all my lines so there clean, Bleed the brakes {a few times } and the darn things still barely stops me rolling down the driveway. what did i miss ? ANY AND ALL HELP IS APPRECIATED.I'm ready to run all new lines if i need to....FYI....plain ol' Disc brakes all the way around My 1963 C10
SICK-T2
SickAss 62 C10 is offline   Reply With Quote
Old 02-19-2015, 09:52 PM   #2
SickAss 62 C10
Re: HELP!!! i can't stop!
Sorry I ment drum brakes all the way around
SICK-T2
Old 02-19-2015, 10:12 PM   #3
TJ's Chevy
TJ's Chevy's Avatar
Did you let the master cylinder sit awhile after you filled it to push the air out? Any air in the system can cause issues like that. Also did you adjust the brakes so you have a slight drag when you turn them by hand?
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 02-19-2015, 10:17 PM   #4
Jim53066
Jim53066's Avatar
The previous owner had all that done on my 65 (all original) and mine stops great. So well in fact that I have made up my mind that it does not need any brake upgrades until something wears out.
I would think that there must be something wrong with your master, or the adjustment of the shoes because with everything new it should stop, maybe not as well as disc brakes, but you should feel under control during normal driving.
The only item I can think of that you did not mention would be the rubber lines, they tend to swell under pressure rather than push the fluid where it belongs.
Jim
Jim53066 is offline   Reply With Quote
Old 02-20-2015, 12:00 AM   #5
Mike Wessinger
Mike Wessinger's Avatar
Agree with the recommendation to check the adjustment. After I did the master cylinder upgrade and brake service, I didn't really notice much difference, that is until I got the adjustment right at the wheels.
1965 Chevy C10 Stepside Shortbed--2012 370Z Base Gun Metallic--2020 Chevy Silverado RST Crew Cab
Mike Wessinger is offline   Reply With Quote
Old 02-20-2015, 12:28 AM   #6
Softpatch
Softpatch's Avatar
did you say new wheel cylinders.?
sometimes the "New" Wheel cylinder are stuck
I have had to exercise them to make sure they not stuck before install
it sound crazy but it happens
...Sp
My Spelling is Not Incorrect...It's 'Creative'
1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E
http://67-72chevytrucks.com/vboard/s...d.php?t=789617
59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341
Softpatch is offline   Reply With Quote
Old 02-20-2015, 01:06 AM   #7
frankslagoon
We don't need know stinken BRAKES. Did you put the same master cly. back on. This is the trk with the pont motor, correct? It looks to me like you have a dual master cly. on that trk. one side for brakes and one side for the clutch. which you ain't got. ya sure you got the brakes hooked up to the correct ram. did you bench bled the master cly.? I suppose ya just bleed both sides and then plug off the clutch side. I'm not really sure. I never went from manual to auto in these early 60's trk. I like manuals.
frankslagoon is offline   Reply With Quote
Old 02-20-2015, 01:15 AM   #8
Green chevy c20
Hi how's it going. I kinda had the same issue with my truck. One thing is did you ever bench bleed the master cylinder. Another thing you can try is to open up the bleed screw on the master. After it took me like 5 to 6 times going around the truck and driving it a little to get all the air out. Make sure you do it in the right order. Right rear, left rear, right front, left front. Hope this helps.
Green chevy c20 is offline   Reply With Quote
Old 02-20-2015, 01:19 AM   #9
SickAss 62 C10
okay guys first off thank you .. Now TJ i used a mighty vac to bleed it.and i did adjust them. yea softpatch i had 1 cylinder get stuck on me but quick fix . Jim53 you make a point about the rubber hoses i have not checked..tomorrow morning i'm looking into that.thanks again guy keep'em coming
SICK-T2
Old 02-20-2015, 01:32 AM   #10
luvbowties
luvbowties's Avatar
Smile Re: HELP!!! i can't stop!
I'd toss my strongly-felt vote toward proper adjustment. I've found the only SURE way to nail it 1st try is to use this method: tighten the adjuster all the way down--the drum will not turn here, of course. Now back off the adjuster until you have that 'slight drag' that is so often mentioned. Go to next drum & do the same. Continue until all 4(Order does not matter.) have been adjusted THIS WAY. Probably solve your problem.
Adjusting by merely tightening adjuster until a slight drag is felt seems to work only occasionally--and this is after the drums have been turned with new shoes installed (& hopefully tru-arced, when you can still find such a machine). Anything less, and the 1st suggestion seems to give, by far, greater results.
HTH,
Sam
luvbowties is offline   Reply With Quote
Old 02-20-2015, 01:24 PM   #11
SickAss 62 C10
Well Green Chevy no i did not bench bleed thought that was only for power brakes, i'm gonna try adjusting them {AGAIN} First, then if i need to start all over with bench bleeding i will
SICK-T2
Old 02-20-2015, 01:38 PM   #12
Figuarus
Figuarus's Avatar
I might be late to the party, but did you bleed the brakes in the right order?
Usually done as longest line first (Pass rear,Driver rear, Pass front, and driver front)
I can't remember why, But I remember my dad teaching me this when I was a kid.
2013 Malibu LTZ
1996 C1500 4.3/5spd 2wd
Figuarus is offline   Reply With Quote
Old 02-20-2015, 01:51 PM   #13
SickAss 62 C10
Sure did Figuarus
SICK-T2
Old 02-20-2015, 03:31 PM   #14
TJ's Chevy
TJ's Chevy's Avatar
Bench bleeding works for both power and manual...all it is in Uncle Matt telling Aunt Dorthy to push the brake pedal to the floor while he has the bleeder screw opened. Have you tried pumping the brakes while you stop? Also...does the pedal seems to have alot of travel...like you can almost push it to the floor?
Old 02-20-2015, 04:14 PM   #15
SickAss 62 C10
sorry TJ thought i mentioned But guess i didn't, pedal dose go down to the bottom then kinda grab
SICK-T2
Old 02-20-2015, 04:25 PM   #16
KJSR
KJSR's Avatar
Does your pedal get better when you have the ebrake on?
1936 Chevrolet 1/2t
1964 Chevrolet C10
1964 Chevrolet C10 (sons)
1965 Chevrolet K10 Suburban
1969 Chevrolet C10
1937 Plymouth P4
KJSR is offline   Reply With Quote
Old 02-20-2015, 04:26 PM   #17
TJ's Chevy
TJ's Chevy's Avatar
Yeah if you have to pump it that normally means you either don't have enough fluid, air in the system, or the adjustment is to loose.
Old 02-20-2015, 04:36 PM   #18
SickAss 62 C10
gonna check it out later. i'll let you know how it goes thanks
SICK-T2
Old 02-20-2015, 09:15 PM   #19
SickAss 62 C10
RIGHT ON FELLAS !!!! looks like we got it . Seams all i needed to do was a better job at adjusting the rear and were good. Like i said at the beginning ALL was and is appreciated, THANK YOU GUYS. now the next issue tranny problems gonna try and tackle it on my own first. if not you will be seeing another thread
SICK-T2
