Old 03-08-2015, 01:00 PM   #1
jose gutierrez
3 inch exhaust
Is a 3 inch exhaust doable for a 65 c10 or is there kit I can bay ?
jose gutierrez is offline   Reply With Quote
Old 03-08-2015, 01:42 PM   #2
Hollow65
Hollow65's Avatar
Re: 3 inch exhaust
Definitely doable, I run 3" with an (H) pipe. It used to run out the back but I changed it to dumps after the mufflers right behind the cab.
At my worst I'm at my best
Hollow65 is offline   Reply With Quote
Old 03-08-2015, 02:14 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: 3 inch exhaust
You can fit a 3" but if you don't need a 3" pipe, there isn't anything to be gained from doing so.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 03-08-2015, 02:34 PM   #4
Hollow65
Hollow65's Avatar
Re: 3 inch exhaust
Brew is right, if your not runnin balls out, go 2-1/2 and run some 3" tips if you like the look of the bigger pipes.
Old 03-08-2015, 08:39 PM   #5
Jimal
Jimal's Avatar
Re: 3 inch exhaust
I'm considering going with a single 3" or maybe 4" exhaust for the 400 in my K10. Everybody does duals, including my truck's PO, but they're harder to route around the transfer case.
Jimal is offline   Reply With Quote
Old 03-08-2015, 09:15 PM   #6
LVPhotos
LVPhotos's Avatar
Re: 3 inch exhaust
Unless you are running 500 hp there is no reason to run anything over 2.5". Same goes for my Cummins over 4" kills performance over benefits!
http://powerblocktv.com/post/the-top...s-for-your-car
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 03-08-2015, 09:19 PM   #7
brettster
Re: 3 inch exhaust
I would say if your not running 500+ horsepower then 3 inch exhaust would be major overkill.
brettster is offline   Reply With Quote
Old 03-08-2015, 09:32 PM   #8
par4tom
Re: 3 inch exhaust
I'm running a 400+ hp 383 stroker. Is 2 1/2 inch going to be enough? Just street cruising...
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=705185
How to Get Audiophile Sound in 60-66 Trucks
http://67-72chevytrucks.com/vboard/s...=1#post7236896
Building Your Own Speaker Kick Pods
http://http://67-72chevytrucks.com/vboard/showthread.php?t=730495
par4tom is offline   Reply With Quote
Old 03-08-2015, 09:38 PM   #9
brettster
Re: 3 inch exhaust
Yes,should be perfect,Run 3 inch tips for the fat pipe effect.3 inch exhaust is for the strip.IMO
Old 03-09-2015, 11:40 PM   #10
jose gutierrez
Re: 3 inch exhaust
I wonder if this kit from flowmaster will work
FlowmasterŽ Part #: 817654
Category Exhaust Systems / Kits - American ThunderŽ
Description Crossmember back 409S - Dual Rear or Side Exit - Moderate/Aggressive Sound
Installation File Download File Here
Material 409S Stainless Steel
Price: $668.95
Old 03-10-2015, 02:20 AM   #11
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: 3 inch exhaust
Thats for the 67-72, but with the frame similarities you can probably make it work if you don't mind making a few slight adjustments to the hangers etc.
I generally don't think about buying "kits" for projects like this (i.e. non-latemodel stuff). Some racing shops or real custom exhaust places can put together a nice exhaust for less than a kit will cost with more freedom in muffler choice, routing etc.
Not every area has a legit place (and bad exhaust shops are just that, bad)...but if you do they are worth getting to know. Those same places are invaluable for stuff like intercooler piping if you ever wind up needing it.
Old 03-14-2015, 07:29 AM   #12
luvbowties
luvbowties's Avatar
Smile Re: 3 inch exhaust
X2 with ^^^^^. BR3W CITY is giving good advice. Get personal references from previous customers & get a muffler shop to do the exhaust work--some jobs you just cannot take away from the "pro's".
Sam
luvbowties is offline   Reply With Quote
