Steering column interchange
I want to put a tilt steering wheel from a fixed one on the 79. Do all columns interchange from 73-87? Also I bought one of those steering wheels from a early 80s S10, the horn button is all that needs changed right?
thanks
79 Chevy 2wd BIG10 350 TH400 Last edited by truckin 79; 03-12-2015 at 01:01 PM. |
78K & 79C Jimmys
Re: Steering column interchange
they do but the "swapped in"lower shaft prob needs to be used with it
Some do have different rag joints. And of course the later years have more power control wires.ie wipers/dimmer.
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
They are not a straight swap physically due to intermediate shaft changes as stated. The wiring is similar on things like turn signals, but the connectors change every few years or so, but can be repinned easily with a pick tool. It's best to pull from the same year if you want an easy swap. If not, be prepared to do some modifications.
As far as the horn button, the steering wheel is all integral. The only reason to change the button is if you need a GMC button or something. Otherwise, just feed the connector through the hole on the new wheel and plug it in. Looks exactly like the GMC wheel I got for my '74 from a 90's C1500.
- 1981 Sierra 454, NV4500 swap - 2006 Z06, 25k miles - 1973 Nova - Project CarNova Virus on Youtube |
Great thanks, that helps a lot. I cant wait to change to a tilt, right now the steering wheel basically sits on my legs.
79 Chevy 2wd BIG10 350 TH400 |
