![]() Join Date: Feb 2010
Hubcap ???
Anyone know if 66 van hubcaps fit our stock rims? I picked up a set off ebay and they are really shallow. I also picked up a set of caps that are similar to c20 caps. But they have a really wide ring! What rims are they for? Thanks
Tom |
![]() Join Date: Aug 2013
Re: Hubcap ???
no and 3/4ton!!! the van caps are too shallow to fit over the nubs and hold tightly, the wide inner ring is for wheels with the clips... post a few pics, but im sure thats what u have, i been down that road many times!!! that backside of the hubcaps tells the tale...
Re: Hubcap ???
My c20 caps are different than these. These have a really wide ring. Are they for the 19.5 rims?
Re: Hubcap ???
Yeah ill post some pics later. But i know my c20 caps are correct. I dont think the wider ring will fit my 16" rims.
![]() Join Date: Nov 2014
Re: Hubcap ???
Oh man, I thought I was gonna find another avenue to locate c20 hubcaps.
![]() Oh well. I'd like to see a pic also. just for curiosity sake. |
Re: Hubcap ???
![]() Join Date: Aug 2010
Re: Hubcap ???
In a nutshell, there are just a few thing to keep in mind for fitment:
1) Ring or no ring. All NO RING caps fit 1/2 TON trucks with nubs and NO CLIPS , except van caps, which look identical front and back, but are too shallow. 2) Wide ring or narrow ring. These are for wheels with clips. A wider ring makes for a smaller opening. Smaller opening means 1/2 TON. Narrower ring makes a larger opening. These are for 3/4 TON. No such thing as a ringless cap for 3/4 ton in our generation. It's pretty simple once you can recognize the differences. |
#8 | |
Re: Hubcap ???
![]() ![]() Join Date: Apr 2012
Re: Hubcap ???
Hubcaps from left to right.
1/2 ton Nub style 6 bolt rims 1/2 ton Clip style 6 bolt only rims 3/4 and one ton 8 lug clip style rims ![]() ![]() Hope this helps
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
Re: Hubcap ???
Thanks for the pics!
A picture is truly worth a thousand words! |
Re: Hubcap ???
Wait. Left to right? That would make the larger cap to the left for a 1/2 ton, and the smaller cap to the right for 3/4 ton?
Re: Hubcap ???
The one on the left fits over nub wheels. Physically these caps are all the same exact outer diameter . IF it looks bigger, its the picture . Only difference is whats done to the back. I have swapped the clip rings from one cap to another , a few guys have taken rings and put in nub caps.
#13 |
[QUOTE=oem4me;7132861]
In a nutshell, there are just a couple things to keep in mind for fitment: 1) Wide ring or narrow ring. These are for wheels with clips. A) wider ring makes for a smaller opening. Smaller opening means 1/2 TON. B) Narrower ring makes a larger opening. These are for 3/4 TON. 2) All NO RING caps fit 1/2 TON trucks with nub rims without CLIPS, except van caps, which look identical front and back, but are too shallow. No such thing as a ring less cap for 3/4 ton in our generation. QUOTE] So my 15" clipless/nubbie rims will accept any ringless hubcap except the van caps? How much shallower are they? Dimensions so not to get wrong cap... ![]()
Projects: 65' Chevy C10 swb (rebuilt chassis) 65' Chevy Panel swb 64' Chevy C30 flatbed "above" 80' C30 "beneath") Parts: 66' GMC 2503 & 65' GMC I1500 |
#14 |
Re: Hubcap ???
Ok i think i have it straight now.
Upper left: 1/2t cap Lower left: 3/4t cap both undisputable as i have both style rims Middle lower/lower right: 1/2t clip type (in 66 really?) Middle upper/upper right: Van? (Shallow and 9.75 dia) Last edited by rideblue00; 04-14-2015 at 09:58 PM. |
#15 |
Re: Hubcap ???
I just want to be sure that the shallow ones are van ones. (What else could they be lol) i need to re-sell these as i cant use them.
#16 | |
Re: Hubcap ???
WANTED: * 60-66 Chevy and GMC FACTORY PHOTOGRAPHY (scans) of pickups and carryalls. Custom Camper Club-- Own a 65-66 Custom Camper? Join us at: http://67-72chevytrucks.com/vboard/g...hp?groupid=117 |
#17 |
Re: Hubcap ???
#18 |
Re: Hubcap ???
Good info there! This post keeps getting longer lol
