Old 04-20-2015, 05:37 PM   #1
canadian_diesel1964
283 oil filter adapter ...which is best?
My question of the day...what is the best oil filter adapter to change from the canister syle to spin on? .....here's my set up now...I've heard some leak and some are good...thank you
canadian_diesel1964 is offline   Reply With Quote
Old 04-20-2015, 06:10 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: 283 oil filter adapter ...which is best?
It's been too many years for me to remember brands, but the first one I ever used on my 283 back around 1975 actually cracked and fell off the engine (taking the filter with it) after about a year of service. The first I knew I had a problem was when the rods started knocking. I looked down and saw zero oil pressure.
It wiped out the rod bearings on the crank but didn't hurt the engine. I got really lucky and picked up a 10 under crank, and set of 10 under bearings, and slapped it back together with no additional problems. I don't remember clearly, but I'm pretty sure I went back to the bolt on metal cartridge canister.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 04-20-2015, 06:40 PM   #3
canadian_diesel1964
Oh man ...ok the canister is looking better
Old 04-20-2015, 08:11 PM   #4
raymo66
raymo66's Avatar
My spin on adapter weeps oil even with a new o ring. So was thinking
can you buy a new canister set up? or wrecking yard only?
raymo66 is offline   Reply With Quote
Old 04-20-2015, 08:43 PM   #5
frankslagoon
I been changen the canisters out since the late 60's and haven't had any more trouble than the canisters leakin. just put em on with loc tight and don't tighten to tight. the spin on are 10 times easier to use and find. those old canisters are a mess. Little tip my buddy does is put a tie fitting in the oil pressure line so we have a oil light and a gauge. he lost a pickup tube and had the music wide open if he hadn't seen the light he wood have lost the motor.
frankslagoon is offline   Reply With Quote
Old 04-20-2015, 08:52 PM   #6
canadian_diesel1964
I heard the wix 24061 kit is good
Old 04-20-2015, 09:34 PM   #7
LDO
LDO's Avatar
One of the adapters I used, requires you use your stock piece (the one you pictured) underneath, otherwise, it will warp when you tighten the bolts and cause a leak.
LDO is offline   Reply With Quote
Old 04-21-2015, 03:55 AM   #8
wbc409
[QUOTE=LDO;7141583]One of the adapters I used, requires you use your stock piece (the one you pictured) underneath, otherwise, it will warp when you tighten the bolts and cause a leak.[/QUO
make sure that you use the correct length of bolt when you install the transmission when you switch to a spin on filter adapter. If you use to long of a bolt in that spot it will Crack the filter adapter
wbc409 is offline   Reply With Quote
Old 04-21-2015, 05:33 AM   #9
65chevysub
65chevysub's Avatar
[QUOTE=wbc409;7141995]
Originally Posted by LDO View Post
One of the adapters I used, requires you use your stock piece (the one you pictured) underneath, otherwise, it will warp when you tighten the bolts and cause a leak.[/QUO The one I have is a Mr. Gasket I believe. Its been OK since 1996 but had the filter vibrate off twice. I didn't double check the tightness so it was kind of my fault. I check it about once a month
65chevysub is offline   Reply With Quote
