![]() Join Date: Feb 2009
WTB - Looking for mint lenses, trim moldings, steering box
1971 Chevy, 1971 OEM parts/replacements only (e.g., NOS)....
One amber deluxe marker lens 911310 One LH back-up lens 5961257 Two standard red marker lenses 916087 RH upper tailgate molding with clips. 3917742 Interested in the cab trim under the rear window. (Not sure the part numbers yet). The LH on my truck is about 90%, but the RH is about 50%. I suspect the LH can be clean again, but probably not the RH. Any advise how to straighten these out is appreciated. Interested in a new frame for around the rear window. (don't know the part numbers yet). I don't believe the LH was installed right, because it's partially bent against the seal, for about 6" (that normal?). The lower is wasted. The RH is pretty good, just one small ding. Also, any recommendations for a new seal is appreciated. Soon I'll be looking for a steering box. Of course I don't expect a mint 71 OEM. I prefer it be like-OEM, excellent quality, and with luck all connections the same, but I'm all ears. ................. If you have something, please contact me with your price. I prefer to use PP......Thank you
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 05-07-2015 at 11:52 PM. |
