Old 05-11-2015, 10:55 AM   #1
beaterku
beaterku's Avatar
18x9" 5"BS on front?
Good morning all,
I am going to order wheels this week for my 72. Right now it has stock front spindles that the PO has cut to lower the front slightly. I am eventually going to get a set of drop spindles and springs or air ride on the truck. My question is, will as 18x9" with a 5" backspace with a 255/50/18 fit on the front? I want to run a square setup front and back.
My current wheel/tire combo is a set of 15x8 4.5" BS Centerlines with 295/50/15 tires all around that the PO put on.
Thanks!
beaterku is offline   Reply With Quote
Old 05-11-2015, 04:11 PM   #2
67chevemall
67chevemall's Avatar
Re: 18x9" 5"BS on front?
Yep they will fit. I run 18x10 with 275 35 18 on the front and back
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 05-11-2015, 04:46 PM   #3
beaterku
beaterku's Avatar
Thanks. Crunching the numbers, they fit. I wanted to see what other members were running to get some real world numbers.
Old 05-11-2015, 04:53 PM   #4
rex01atv
They will work fine, my old wheels were 18x9 with 4.5 bs on all four. Your wheels will be 1/2 tucked in further..
rex01atv is offline   Reply With Quote
Old 05-11-2015, 10:25 PM   #5
knomadd
knomadd's Avatar
If you haven't checked this online tool out yet, I highly recommend it. I use it all the time. It's very helpful. http://www.rimsntires.com/specspro.jsp
Also, I'm not sure if it's intentional, but the tires you say you have are 26.7" tall and the tires you say you want are 28.1" tall. Are you sure the sizes you listed are correct? Your speedometer will read faster with the 18s you have listed.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 05-11-2015, 10:32 PM   #6
beaterku
beaterku's Avatar
Thanks!
The PO put these tires on. They are too short for my taste. My speedo reads fast with the short tires. I am killing two birds with one stone with a taller tire.
The Rimsntires site is a great tool! I have been using it for years as a quick check on offsets.
That's a good looking truck you have there!
