Old 06-12-2015, 03:38 PM   #1
johnboy1861
johnboy1861's Avatar
Drop measurement question?
Hey guys, I am trying to find out what the distance between the bumbstop and the axle u-bolt is for guys running a 4" or 5" drop with out a c-notch. The reason I ask is, the PO thought it would be a good ideal to cut the center coil out of the rear springs and weld them back together, so I have no idea how much of a drop this is. I like the ride height and would like to keep the same drop, but definitely need some new springs and don't want to have to c-notch the frame. The way it sits, I have 1 1/2" between the bumbstop and the axle u-bolt. The center of the fender lip to the ground is 29 3/4" with 275/60 15's on 15x8 rallies. I have 2 1/2" between the tire and the fender. This is on my 72 2wd SWB fleet. Thanks guys.
johnboy1861 is offline   Reply With Quote
Old 06-12-2015, 03:43 PM   #2
johnboy1861
Re: Drop measurement question?
And forgot to mention, the gas tank is in the cab. No extra weight in the rear.
Old 06-19-2015, 08:04 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
I have a 275/60 on my red '69.
It has ECE 6" drop springs and 1.5" lowering blocks.
My measurement is 27-1/8" at the rear wheelwell.
Keith
Convert to disc brakes.
