Old 09-05-2003, 10:22 PM   #1
SWINGSAX68
Now the others dig........
SWINGSAX68's Avatar
HELP with power brake set up
Well, I got it all on and bench bled the Master Cylinder. It is an original 67-72 booster and master cylinder. I didn't have time to bleed the wheel cylinders....with out the truck running the pedal is pretty easy to put down all the way. Is that supposed to happen since i haven't bled the wheel cylinders????
Also the pedal rod does not allow the pedal to rest on the rubber stopper when the brakes are not applied, is that supposed to happen????? and I need to adjust the stop lamp switch but one of the nuts is really tight and I cant move it....any suggestions???? I also noticed that my engine does not idle as rough as it did with the other booster that I had rigged....could a vacuum leak cause rough idleing????? THANKS GUYS!!!!
68 Chevy C10 Stepside Black Primer
78 GMC Longbed White
09 Chevy Silverado Shortbed Granite Blue
LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala
MEMBER OF THE DRUM BRAKE CLUB
Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX
Certified Music Educator
I hope Mom is up there watching and being my Guardian Angel
"I've got a fever.....and the only prescription.....IS MORE COW BELL"
-The Legendary: Bruce Dickenson
"F#$@ 'em up!!!!!!"
-The Legendary: Rogelio Escobar
TRUCKY LINKS
http://67-72chevytrucks.com/vboard/s...d.php?t=457750
http://67-72chevytrucks.com/vboard/s...d.php?t=461184
http://67-72chevytrucks.com/vboard/s...d.php?t=472848
http://67-72chevytrucks.com/vboard/s...d.php?t=417541
http://67-72chevytrucks.com/vboard/s...d.php?t=477788
SWINGSAX68 is offline   Reply With Quote
Old 09-05-2003, 11:42 PM   #2
SWINGSAX68
SWINGSAX68's Avatar
18 VIEWS NO REPLY???COME ON GUYS...i HAVE TO GO TO WORK TOMMOROW AFTERNOON AND I NEED HELP STAT!!!!!
THANKS IN ADVANCE
"F#$@ 'em up!!!!!!"
TRUCKY LINKS
Old 09-06-2003, 12:00 AM   #3
neonlarry
neonlarry's Avatar
Yes, the brake pedal will go to the floor if you haven't bled the wheel cylinders. Yes, a vacuum leak will cause a rough idle.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 09-06-2003, 12:17 AM   #4
SWINGSAX68
SWINGSAX68's Avatar
THANKS NEON LARRY!!!!!!NOW HOW ABOUT THE PEDAL SITTING FARTHER DOWN WHEN NOT APPLIED??? iT DOESN'T HIT THE RUBBER STOPPER, IT'S GOT A GOOD 1 1/2 INCHES OF SPACE BETWEEN THE PEDAL AND STOPPER???? DID I GET THE WRONG BRAKE ROD????WAS THE 67-68 BRAKE PEDAL ASSEMBLY DIFFERENT THAN OTHER YEARS??? THE BOOSTER CAME OFF A 69 i THINK....WILL THIS CAUSE ANY BRAKEING PROBLEMS????? WOULD THIS CAUSE THE BRAKES TO NOT APPLY CORRECTLY IN AN EMERGENCY OR SUCH??? sORRY ABOUT ALL THE QUESTIONS....
-ROGER
"F#$@ 'em up!!!!!!"
TRUCKY LINKS
Old 09-06-2003, 02:14 AM   #5
krue
Designated A-hole!
krue's Avatar
For the brake light switch, all I know to tell you is it's a Biatch! There is adjustment in the rod between the pedal and the booster. You may also have to adjust the rod between the booster and M/C. I had to do it by trial and error. Good luck!
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
