late model wheels?
Will the 6 lug wheels off of a late model Chevy truck fit a '66 truck?
Thanks |
Re: late model wheels?
I have these on mine
![]() Join Date: Jun 2013
center hole might be too small on wheel
These bolted on with no mods. They will be coming off for some steel wheels soon.
Pretty much any 6x5.5 bolt patten will work, just depends on the size of the center hole. I'm running 6lug steels from a Toyota FJ
depends on how you classify late model. 4x4 wheels from the square body era are nice and a bit wider than the 2x4 versions so you can load them up with big meats. The PO put them on my truck. I painted them up and bought the centers off e-pay for less than 100 beans.
The GMT400 6 hole wheels will NOT fit on the older trucks because:
1) the center hole is too small, but you could cut them out 2) the backspacing is totally different and the wheel will hit the tie rod end on the front, and maybe the leaf springs on the back Don't ask me how I know ![]()
Current/past Chevy/GMC trucks: 1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner |
#8 | |
What does GMT 400 mean?
GMT400 is the '88-98 Chevy and GMC trucks.
1982 K10 SWB 1987 V20 - Sold - Doh! |
Sorry - I thought everyone knew that
![]() Anyway, that's when they went back to the 16" wheels for half tons.
#13 | |
Might be all right for a show truck, but adaptors have a bad reputation on the 4x4 forums. I sure don't need my damn wheels falling off of a 6000 pound Suburban ![]()
#14 |
I run 1.5" wheel spacers on my JK 4dr, weighs around 5500Lbs, 5.5" lift, long arms & 37s, and it's a daily driver, and never had a problem with wheel studs, loose wheels or dangerous anything. Just make sure they are torqued properly and some red Locktight helps too.
I'll probably need to throw some 1" spacers on my rears on the 65, I don't see any issues. |
