Old 07-25-2015, 08:19 PM   #1
mjgord51
replacing rear brake"studs"
PO had replaced pass side rear axle studs with longer studs, here is my problem I am using 1 1/2" wheel spacers and it doesn't allow my rim to fit flush on the spacer, studs stick out 1/8 to 3/16" more, I have a temp fix with flat washers only for rolling it around ( not real safe for driving) * * My question is will the studs pop off and on with out the aide of a Press * *
mjgord51 is offline   Reply With Quote
Old 07-25-2015, 08:32 PM   #2
frankslagoon
Re: replacing rear brake"studs"
I don't really understand what your tryin to do. but if ya screw the lug nut on the stud a few threads you can pound the studs out with a hammer then take the lug nut off and remove the stud or just pound the studs out without the lug nut screwed on but the stud will be wasted for sure
frankslagoon is offline   Reply With Quote
Old 07-25-2015, 10:49 PM   #3
mjgord51
I am trying to get the studs off and then install stock (new) ones back on " with out" the aide of a hydraulic press,
Any body else that has did this please " chime " in. Thanks, mjgord51
Old 07-25-2015, 10:59 PM   #4
swamp rat
swamp rat's Avatar
I tried the big hammer trick (2 lb) on my K20, could be done but was a pita, i used my press, your hubs may be easyer? only way to know is to try.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 07-25-2015, 11:15 PM   #5
colgad
colgad's Avatar
Yea, just use a hammer, two or three hits should do it.
1967 Red, C10 Short Bed 6.0L T5 5 speed
1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup
1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH
1955 Red-Cream, Chevrolet Nomad, restoration on hold
2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour
colgad is offline   Reply With Quote
Old 07-26-2015, 01:32 AM   #6
luvbowties
luvbowties's Avatar
Smile Re: replacing rear brake"studs"
X2 ^^^^^^^
Sam
luvbowties is offline   Reply With Quote
Old 07-26-2015, 03:03 AM   #7
frankslagoon
They usually pound out pretty easy. the hard part is getten the new ones to pull back in good and tight.. I use a air wrench and some old lug nuts and don't try and use the same nut to pull over a couple studs tight or the lug nut will wear out and strip your new studs
Old 07-26-2015, 03:40 PM   #8
Redline novdog
Redline novdog's Avatar
I usually hammer them out. Pull them back in with a nut taper side out with a couple of greased/oiled washers in between the nut and hub face.Sometimes space permitting a c-clamp works with a socket over the threads. I've never had the opportunity to use a press.
It builds on my intelligence when I make a mistake, Boy am I building on it!
'67 C-10,'70 Nova SS
Redline novdog is offline   Reply With Quote
Old 07-26-2015, 04:49 PM   #9
GRX
GRX's Avatar
Not a good idea to use the threads to install the studs. Use a stout c-clamp and piece of pipe or deep impact socket over the stud to install them.
Make sure the spline on the new studs are the same diameter as the old.
GRX is offline   Reply With Quote
Old 07-26-2015, 05:13 PM   #10
mjgord51
We have two things in common, Old black chevy trucks and novas, mine a 68 C10 and a 64 Chevy II, now that we have shaken hands I'll give this a try but dont understand what the gressed/oiled washers will do,
PS The 22's on the Truck got replaced real fast like, I don't like wagon wheels but I can understand that some people do! Just not me, LOL The ChevyII I have just found a new bullet for it 6 cyl, I know how has a 6cyl any more well I do!
Old 07-26-2015, 05:28 PM   #11
mjgord51
I will have to look and see if I have enough room for the C-clamp, The rear axle is still in the truck
Old 07-26-2015, 07:23 PM   #12
Stocker
20' Daredevil (Ret)
Stocker's Avatar
It's kinda like a very basic bearing. Most of your mechanical force will go towards pulling the stud in to seat it, with less energy lost by the nut grinding tightly against the drum.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 07-26-2015, 07:43 PM   #13
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: replacing rear brake"studs"
Your not going to reuse the studs so knock them out with a hammer.
To install the new ones with a couple of old lug nuts to pull them up tight. May want to put some washers between the backing plate and lug nut when tightening them up. That's how I do it anyway. Using some kind of lube would be fine to. Just make sure the lug nuts you use are in good shape.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 07-26-2015, 08:48 PM   #14
Redline novdog
Sorry GRX must have been doing wrong for thirty years. Mjgord51 I get it your truck is more modded my nova is more modded, kinda like a space time worm hole deal LOL!! Beautiful truck and sweet lookin' Chevy2! Good luck!!
Old 07-26-2015, 09:02 PM   #15
GRX
GRX's Avatar
Not wrong. Have fixed some for customers with distorted threads from drawing them in with nuts is all I was trying to say.
