Old 07-28-2015, 01:41 PM   #1
69Tom
69Tom's Avatar
Power disc front brakes for my '70 - question
Hey guys. Now that I have my truck, I'm interested in making a couple upgrades to it, mainly to make it a little safer driving in traffic around here. First one I'm interested in making is converting to power disc front brakes. It currently has non-power drum brake all the way around. I'd like to use stock GM stuff, if possible.
Essentially, what should I be looking to buy?
I know I need a booster with a front disc master cylinder. What will I need for the front discs--what will fit?
And I know this isn't the place for a WTB, but if anyone has anything....
69Tom is offline   Reply With Quote
Old 07-28-2015, 02:01 PM   #2
michael bustamante
michael bustamante's Avatar
Re: Power disc front brakes for my '70 - question
the easiest and least expensive way is to find a 71 and up doner truck and swap everything over. least amount of mods will come from a 71-72
1967custom
michael bustamante is offline   Reply With Quote
Old 07-28-2015, 02:12 PM   #3
summitflier
summitflier's Avatar
You'll also need a proportioning valve.
As far as I know there is only one size if you go stock oem gm.
You'll need the calipers to go with the disc's.
You'll need disc brake spindles.
If you don't care about stock OEM, it seems wilwood owns about 90%
of the aftermarket. You can get several different sizes, but if you go large,
you'll have to have bigger wheels.
If you're planning on doing the rear also, it requires yet a different master cylinder.
(different size wells). Also the rear disc's require a different emergency/parking brake cable setup.
I was able to save a lot of my original drum brake lines, but the connecters to the calipers are different. (In my case, banjo style).
I assume you have a fairly stock engine setup. If you have a radical cam street/strip type engine, you have to make sure you have enough vacuum for the booster.
68 C10 SSB 383
12 Charger 6.4L
12 Accord 3.5L (Wife's ride)
05 Ram 1500 5.7L
My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=676545
summitflier is offline   Reply With Quote
Old 07-28-2015, 02:48 PM   #4
FirstOwner69
FirstOwner69's Avatar
Here's a thread with the info you need.
You may want to contact forum member "t korinek" (first name is Tom) in Mesa. A couple years ago, I bought everything I needed for my 69 3/4 ton from him. I got a master, booster, prop valve and complete front suspension including the cross member. He'll probably be able to set you up.
Jim
FirstOwner69 is offline   Reply With Quote
Old 07-28-2015, 02:56 PM   #5
69Tom
69Tom's Avatar
Thanks guys. I appreciate the help. Thanks for the info Jim.
Old 07-28-2015, 07:02 PM   #6
tcrist
Isn't the 71 a 5 lug? If so, you would have to do something to the rear end to match everything up.
Terry
Soon to be retired and moving to Bristol, TN.
tcrist is offline   Reply With Quote
