Old 08-01-2015, 11:10 PM   #1
Matthewjb
One piece floor question
Hi everyone, this question is for those that have installed a one piece floor. About how many hours did it take you to complete once the old floor is removed. I've got to tackle this project and was just looking for ballpark estimate. I've also to install both cab corner, both pillars by kick panels, both kick panels, outter rockers, and firewall. Here is a pic where I currently am.
Thanks for the help!
Matthewjb is offline   Reply With Quote
Old 08-01-2015, 11:11 PM   #2
Matthewjb
Re: One piece floor question
Sorry, I'm having issue of posting picture straight on my phone. Hope the pic helps..
Old 08-02-2015, 01:25 AM   #3
68wannabe
After the old floor is out, it shouldn't take that long. It only took me and a buddy around an hour to get it welded in.
68wannabe is offline   Reply With Quote
Old 08-02-2015, 09:37 AM   #4
Matthewjb
Thx for the feedback, anyone else have similar experience? Also what kind of total time y'all think I'm looking at for everything I listed
Old 08-02-2015, 12:04 PM   #5
jaros44sr
jaros44sr's Avatar
Speed kills, take your time and do it right the first time. Rushing to get the job done only causes mistakes, enjoy the challenge of doing the restore. If you have a spot welder it should go faster. Post up pics, getting the area around the trans tunnel, seems to give most people problems
When I did it for a friend, it took weeks
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 08-02-2015, 01:43 PM   #6
jakewalter
jakewalter's Avatar
Take lots of measurements.
Jake
1967 Chevy SBSS Bone stock
1974 Chevy Cheyenne 4wd long bed
1985 Chevy Scottsdale 4wd long bed
2000 Chevy 1 ton 4wd dually quad cab
2004 GMC Sierra 4wd Super cab long bed
jakewalter is offline   Reply With Quote
Old 08-02-2015, 06:25 PM   #7
Redline novdog
Redline novdog's Avatar
WOW!!! looks like My Nova when I back halfed it. You did a good job supporting it!! If time is problem you shouldn't be doing it in the first place.Take your time and do it right!!!Have fun and learn something ! I do everyday1!!!
It builds on my intelligence when I make a mistake, Boy am I building on it!
'67 C-10,'70 Nova SS
Redline novdog is offline   Reply With Quote
Old 08-02-2015, 06:40 PM   #8
57taskforce
All about them K’s
57taskforce's Avatar
Thats a pretty cool method of lifting the cab youve got there. I dont think ive seen anything like that before.
Tyler
57taskforce is online now   Reply With Quote
Old 08-02-2015, 10:59 PM   #9
Matthewjb
57task force, it was a quick set up too, so that was a plus. I definitely will take time to do it right because I know you'll pay for it if not. Thx for all the Input. I'll post some pics once the cab is finished up!
Old 08-03-2015, 08:05 AM   #10
jaros44sr
jaros44sr's Avatar
The only problem I see is that you won t be able to install you re doors with the bracing in the way,JMHO
SAFETY FIRST
AS usual, off topic
Jim
Old 08-03-2015, 08:28 AM   #11
Matthewjb
Jim, I was thinking With the rear pillars being original that height for the floor is good. Also, the front pillars should not have budged a bit since they were braced. Before I started the resto the doors open and closed like a charm. So I'm hoping that once the floor is tacked in and cub is supported I can take braces off and begin to fit doors to make sure the height of the floor is right. Thoughts?
Old 08-03-2015, 08:56 AM   #12
jaros44sr
jaros44sr's Avatar
Hoping is not a good thing with gaps, fitting doors before final weld of floor is what I would recommend. If you can change bracing to fit doors, now is the time. I only had two braces, back wall of cab to the firewall, and that kept it in place while I massaged the floor in place, gaps ARE critical
SAFETY FIRST
AS usual, off topic
Jim
Old 08-03-2015, 09:01 AM   #13
jakewalter
jakewalter's Avatar
That is why you really need to take LOTS of measurments.
An error of 1/8th inch on one end can mean a huge problem on the other end.
Jake
Old 08-03-2015, 09:20 AM   #14
Matthewjb
I'm definitely with y'all, good points. I will post pics when done I'm sure it will look great
