72 Windshield HELP
Does anyone have any advise or tricks on installing the new windshield on my 72 c10 ? It has the chrome trim.
#2 | |
Re: 72 Windshield HELP
You could look on Youtube. there are many videos on the subject if you want to try it yourself. I did it twice before. 50% success.
"Life is too short to drive a boring vehicle". Later, Wayne ![]() |
![]() Join Date: Mar 2015
This is on my to do list eventually also. So, I personally have not done it, but in researching it seems to vary from "take your time, patience, and it's pretty straightforward" to "this %*#@ sucks, how does this go in!?". Here are a couple of links that may help, hope to hear how it went!
The big tip i have is dont break the glass
Old member
I put mine in with help from my daughter and son.
Put rope inside gasket from bottom to top with both ends of the rope in the top center to pull the gasket in and have some one putting pressure on it while you pull the rope ends a little each way and keep them even. Get it started good and it will go right in. Having some plastic knives will help and a set of picks. Once it's in you can work the top corners into position. Use plenty of soap and water in a spray bottle also. Spray it down good before you start. Also wash the gasket good before doing anything and let dry in the sun. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Thanks for the help and The links, Im going to attempt it this weekend.
