![]() Join Date: Nov 2013
67 250 with a 3 speed
I haven't taken any pictures of it yet. I haven't even pulled it out yet, but I have a 250 inline 6 and a 3 speed in a c10 long bed that I bought for the cab only. It runs decent not like new by a long shot but runs good enough that I have drove it around the yard a couple times. Not to much as it doesn't have any brakes. It needs a starter but the old one still works it just does a lot of screeching. I would take $350 for the pair or $200 for the engine alone and $150 for the transmission.
Re: 67 250 with a 3 speed
Sent a PM
I had time to go take picture this evening. |
bump
![]() Join Date: Aug 2010
Would you part with just the air cleaner and stove pipe assembly?
ANDREW 1972 Chevy SWB Cheyenne Super JANE http://67-72chevytrucks.com/vboard/s...d.php?t=462072 1972 GMC Jimmy PENNY http://67-72chevytrucks.com/vboard/s...d.php?t=735827 1968 GMC patina swb PEARL http://67-72chevytrucks.com/vboard/s...d.php?t=731315 1972 Chevy K20 BRUCE http://67-72chevytrucks.com/vboard/s...d.php?t=805788 |
For right now I would rather keep it as 1 unit, but if I do decide to strip it apart you be the first I contact. I do have to ask. Are you referring to intake and carb as a stove pipe assembly.
![]() Join Date: Sep 2007
i dont believe 67`s came with stovepipes. Stove pipes are those metal tubes that feed from the air cleaner neck to the exhaust manifold usually
1967custom |
That was my mistake, it looked like there was one on your motor but I might need a new pair of glasses. Just the air cleaner if you decide to part, thanks
What trans is it? Would you sell the driveline?
Bagged 67 C10 longbed 71 Dodge D100 shortbed |
![]() Join Date: Jul 2010
You still have the crossmember under the bellhousing?
1969 chevy c10 lwb stepside 250 6 3 ott 1971 chevy c10 lwb 250 6 with power steering 3 ott 1972 chevy k20 4x4 350/TH350 automatic 1978 chevy Malibu 4dr 305 2bbl (all original) 1979 chevy k10 Scottsdale 350/th350 full-time 4wd(daily driver) |
#13 |
#14 |
How much you want for it shipped to 44260. If you where closer I'd buy the whole engine.
#15 | |
Posted via Mobile Device |
#16 |
I've seen people say they are the same but since you have both if you could take a quick look I'd appreciate it. I will take it for that price.
#17 |
I'd buy the throttle linkage off the inline 6 too if u still have it. And all the clutch linkage.
#18 |
#19 | |
#20 |
I need the rod that goes from pedal thru the firewall. The zbar I believe it's called the part between frame and engine. and the rod to clutch fork.
#21 | |
#22 |
I will have to think about the clutch linkage I'd be buying it for spare. Definitely want crossmember.
#23 |
#24 |
#25 |
Cool I will take it. I will have to pass on the other stuff due to a tight budget. What's your paypal?
