Old 08-16-2015, 09:14 PM   #1
Sturvin
Stock 15" wheels and disc brakes
Anyone know of a kit that will work with a set of stock 15" wheels? Looking for front kits specifically, not going to get into the rears for now.
I like the look of the wheels now, I would just like to be able to stop.
FYI, '69 c-10, stock 6 lug wheels.
Sturvin is offline   Reply With Quote
Old 08-16-2015, 10:50 PM   #2
rocknss
rocknss's Avatar
Re: Stock 15" wheels and disc brakes
I don't believe the stock 15" 6-lug rims will clear the disc brakes.
Steven
69 Chevy C10 Suburban 350 700R4 w/Disc brakes on all four corners
2017 50th Anniversary Camaro SS
2004 Chevy Impala LS
2016 Chevy Malibu LT
rocknss is offline   Reply With Quote
Old 08-16-2015, 10:56 PM   #3
jocko
jocko's Avatar
Correct - those will not work with a stock disk setup or any kit. You need 71+ K5/K10 15" rims, at a minimum. They are 15", 6 lug, and clear the caliper. Or you can search for the even more rare 6 lug 16" wheels - there are a few out there still.
Old 08-17-2015, 12:07 AM   #4
elf w/capital T
Ive got a front disc brake setup from a 90 burb, yup, 1-1/4 inch thick heavy duty rotors...annnd im using 15 inch rallies. whew close fit and tricky regarding the tie rods but I got it
elf w/capital T is offline   Reply With Quote
Old 08-17-2015, 12:09 AM   #5
elf w/capital T
did go with that stock spindle conversion plate CPP and Classic Perform have, good way to convert over...but I wanted to have the option with drop spindles. so I went that route....not sure if you want to do that...
Old 08-17-2015, 09:04 AM   #6
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Try this.http://www.earlyclassic.com/catalog....version%20Kits Call Stan at Early Classic. They will fix you up.
Tom Vogel is offline   Reply With Quote
Old 08-17-2015, 10:59 PM   #7
jocko
jocko's Avatar
Sturvin - take a look here: http://67-72chevytrucks.com/vboard/s...d.php?t=675448
not exactly what you need, but some ideas.
Old 08-17-2015, 11:49 PM   #8
88Stanger
88Stanger's Avatar
i have a front disc conversion kit i purchased. I have a set of 15" x 8" steelie rims from a 4x4 that i want to use. so will these work with the conversion kit?
88Stanger is offline   Reply With Quote
Old 08-18-2015, 12:38 AM   #9
jocko
jocko's Avatar
depends on the kit. they should work if the conversion kit utilizes stock-size rotors/calipers. big disk kits usually require bigger diameter wheels in addition to the normal extra space for a stock caliper inside the k5/10 wheels.
Old 08-18-2015, 12:52 AM   #10
88Stanger
88Stanger's Avatar
jocko - thanks for the info. I just submitted a new post with pics of the rims. i am painting them this week and need to make sure i am ok.
Old 08-18-2015, 11:23 AM   #11
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
I have a 1972 GMC. I have 15" x 8" slotted mag wheels on the front of my truck. To get them to clear the calipers, I had to do a little grinding on the backs of calipers. Mainly the casting seam area. So it is possible to fit 15" wheels on a disc brake rig.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 08-18-2015, 09:17 PM   #12
jocko
jocko's Avatar
not to beat a dead horse, but you could use these perfect rims, sell the brand new tires, and, well, voila. http://67-72chevytrucks.com/vboard/s...d.php?t=677292
