Old 08-18-2015, 10:52 PM   #1
9teen69
9teen69's Avatar
Time to replace front coils - suggestions
Getting ready to replace upper and lower ball joints and figured I might as well replace the springs while I'm at it. Already bought MOOG ball joints.
Advice/experience with replacement coils...what's the best brand?
A little worried it's going to sit too high.
Can I drop 1" without any issues.
It's my only daily driver, original powertrain w/3OTT. Front and rear sway bars.
Future upgrades, automatic transmission and 15x8 steelies.
leaning toward:
http://www.classicindustries.com/pro...ts/cs6104.html
or:
http://www.rockauto.com/catalog/more...nid=523&jpid=3
72 Cheyenne SWB C10 (daily driver)
(Super fake cause I just love the glovebox emblem)
70 Camaro RS (frame-off in pieces)
70 Camaro RS (daily driver backup)
69 Custom LWB C10 (son now drives)
9teen69 is offline   Reply With Quote
Old 08-18-2015, 11:11 PM   #2
leftybass209
leftybass209's Avatar
Re: Time to replace front coils - suggestions
Early classic enterprises is a great company for springs, and other suspension parts as well. 1" drop won't affect anything, and chances are, your stock springs are already sagging close to an inch, maybe a bit more. If you have the means, you should pull a coil out, measure, then call and confirm a measurement for whatever springs your looking to purchase.
leftybass209 is offline   Reply With Quote
Old 08-18-2015, 11:20 PM   #3
9teen69
9teen69's Avatar
Cool, I'll check them out.
Yeh figured it's sitting a bit lower now, kinda like the height it sits now.
I'll probably bite the bullet and do some measuring before buying.
Doing a little reading looks like I should go with a Variable Rate spring.
thanks
Old 08-18-2015, 11:27 PM   #4
cleanfreak
cleanfreak's Avatar
I've used moog 6082 many times. It is a smaller wire diameter, rides softer , found it to sit slightly lower than others. Bob
cleanfreak is offline   Reply With Quote
Old 08-18-2015, 11:40 PM   #5
9teen69
9teen69's Avatar
Bob- Great, thanks for the info.
