Post Whore
![]() Join Date: Mar 2013
Putting Sway bars on my 66.
Hey guys....I posted in the suspension forum and I haven't gotten any replies...probably cause I'm not patient enough.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
Re: Putting Sway bars on my 66.
TJ, why do you think you need a rear sway bar? Most things I have read seem to think they aren't necessary. I've even heard that they can stiffen your ride and work against you when cornering. Tell me what you have heard.
You might run into clearance issues with the driveshaft, exhaust and possibly shocks if you mounted it on top of the trailing arms.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
#4 | |
Post Whore
Oh crap...I forgot all about the darn driveshaft! Well Darn! lol
TJ,
I installed them on my truck and it made a huge difference. Took a lot of the body roll out of my truck. I am glad I read other post and did my power disc brakes first, because I was going through the curves as fast as I could.
My build thread General JD or Ole Jack http://67-72chevytrucks.com/vboard/s...d.php?t=632318 |
![]() Join Date: Jan 2011
The long track bar and a good set of shocks also help the rear of the truck. When I went to the long track bar it was an improvement from lowering the roll center. The biggest improvement in my truck was going from the KYB shocks to the Bell techs. That was a night and day change. A sway bar will not make much a change in straight line driving but will help the curves a bunch. I also did the caster mod to my truck and had a good alignment shop set the front end up, well worth the effort.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
If you want something that won't interfere with anything I recommend the blade style Hotchkis rear swaybar but it is pricey. My truck had a more traditional style sway bar when i got it but it it was not mounted well.
http://67-72chevytrucks.com/vboard/s...4&postcount=35 |
I will look for the link later but there is a way to install a Camaro sway bar. It is flipped upside down and hugs the rear axle for a cleaner look. I'll post a link once I find it.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
TJ,
I have the No Limits ARB front and rear on my 66 along with relocated Doetsch Racing shocks and Caster mod. The rear ARB was the last thing I did. As a package it really works. Prior to fitting the handling was much improved but afterwards it has given an extra level of balance and neutrality to Woody. Cant help you with you original question but as a mod I would recommend. P. ![]() |
Here is the link I had in mind. Camaro sway bar flipped upside down. You can see it in one of the posts in this thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=572096
Post Whore
Hey guys! Thanks for all the tips and comments!!!! I got my sway bars installed today! Buddy of mine stopped by and we knocked them out. Here's some pictures!
#13 |
Post Whore
Here's a couple more....
