Old 08-24-2015, 09:07 AM   #1
philobeddoe
philobeddoe's Avatar
Under bed spare tire carrier, need one!!
Where the blazes can I get that under bed spare tire carrier, all I need is that long base part that the tire actually rests on. I have all the other hardware. Need help, can't find anywhere!!
77 bonanza, 8 ft. bed. fleetside. (I think they're all the same anyway)
Thanks..
Philippians 4:8, Victory through pure thoughts.
philobeddoe is offline   Reply With Quote
Old 08-24-2015, 12:07 PM   #2
Kaysen
Re: Under bed spare tire carrier, need one!!
Salvage yard would be the best place. Just gotta do some looking around
Kaysen is offline   Reply With Quote
Old 08-24-2015, 02:32 PM   #3
tucsonjwt
I got mine at LMC, but you can check Classic Parts also. Ebay sometimes has them. Most junkyard trucks don't have them since most people remove them to install a receiver style hitch. If you find a glide out/slide out carrier you will be very lucky. I have seen one in my lifetime.
tucsonjwt is offline   Reply With Quote
Old 08-24-2015, 09:38 PM   #4
nonstop
I just went through this. I found only one at the junkyards. I had to straighten it out too.
Makes me want to kick myself for throwing away the glide out that came on my truck.
nonstop is offline   Reply With Quote
Old 08-24-2015, 09:40 PM   #5
Kaysen
I didn't realize they were hard to find. I've hauled off the 6 or 7 I've had for scrap.
Old 08-24-2015, 09:45 PM   #6
Crcrft78
Crcrft78's Avatar
Can you post a picture of what it is your looking for. I'm looking at a truck that has a spare tire carrier under the bed (all bent of course) but want to keep it if it is original and can be repaired.
Crcrft78 is offline   Reply With Quote
Old 08-24-2015, 10:49 PM   #7
midnight rambler
midnight rambler's Avatar
You can also get a spare tire hoist out of a newer truck and bolt that in.
midnight rambler is offline   Reply With Quote
Old 08-25-2015, 07:44 AM   #8
tucsonjwt
I have read that the newer crank down spare tire carriers can be adapted for old squares (drilling a hole in the bumper for the crank handle), but the crank mechanism is subject to rusting in road salt areas. For as seldom as the spare is used, I would stick with the stock set up.
Old 08-25-2015, 08:44 AM   #9
truckfan
truckfan's Avatar
its a great option. so easy. bad pics, sorry
1981 Chevy C30 440 Holmes 42K one owner miles
truckfan is offline   Reply With Quote
Old 08-25-2015, 10:32 AM   #10
Zach079xxx
Zach079xxx's Avatar
Is this the piece you're talking about? This came off of a 1985. This is the only piece I do have, because the rest would not unbolt to save my life. Saw-zaw time but yes, this one is not bent at all. Its in great shape.
Zach079xxx is offline   Reply With Quote
Old 08-25-2015, 06:18 PM   #11
tucsonjwt
truckfan - where did you put the hole in the bumper for the crank handle?
Old 08-26-2015, 09:12 AM   #12
truckfan
truckfan's Avatar
right above the tag. a tire tool goes in pretty good and cranks it down.
