Fan shroud measurements
I have a radiator that I am trying to ID for the purpose of getting a fan shroud for the truck, it being the truck is a 68 C10 I6 3ott. V8 sbc/700R4 now. The radiator in it now ( 3 core ) is for a auto trans and it does look like it does belong to the fitment of the truck. Truck has a two electric fan setup that isn't mounted real good, has only 2 screws on the top for holding it to the core support. Below is a drawing of what I measured, all measurements are real close to what I have here. **IS THERE ANYBODY OUT THERE THAT CAN VERIFY IF THEY ARE RIGHT. Thanks, mjgord51
![]() Join Date: Jul 2015
Re: Fan shroud measurements
Some pics might help
My shroud measures the same as your rad. measurements, all is good in the universe...
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
#5 | |
** just saying ** |
I'm going to use an universal fan shroud kit. Like this one from Summit
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
#7 | |
Another thing. if the truck has no waterpump fan and just the electric fans the stock shroud will serve no purpose, ( in my simple mind).. If it cools fine theres no need unless you want the stock look of a shroud. I keep reading your 1st post and confused. is it going to be the 6 or 8 cyl. when all said and done? If 6 cyl., I think they only had a tin shroud along the top for safety reasons.
![]() Join Date: Jun 2015
If you have a water pump/belt driven fan blade.. the shroud does seem to channel heat better. Also, it's a safety thing. Fingers and fan blades don't mix well.
I switched to elec fans this year. No shroud at all. There are "cages" of a sort around the fan blades for safety. But the biggest thing for me was the room. I don't see a depth measurement in post #1. But I would guess the depth on my old shroud to be about 6 or 7 inches. Now I can move my engine forward if I need to. Run a long water pump if I want. Even run serpentine belt drives if I want.
68 C10 SSB 383 12 Charger 6.4L 12 Accord 3.5L (Wife's ride) 05 Ram 1500 5.7L My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=676545 |
#10 | |
The truck was built as a 68 C10 I6 3ott truck, "now" with V8 sbc/ 700R4 trans, understand now |
#11 | |
#13 |
#14 |
#15 | |
laying low
![]() Join Date: Mar 2001
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
#16 | |
![]() Join Date: Sep 2013
I made this one. Still have the factory one if interested.
71 LWB Large Bore 6-71 Blown 383 Stroker 4.11 Motive/EOM Eaton Posi Ported/Polished Carrier 15x8/15x16.5 MT Radials B&M Pro Shifter Truck Name- Spike |
#17 |
On this site i was told if there isnt any room from the dist (mine a HEI Accel w/super coil) too fire wall (1/4" or 1/2") then engine is in I6 mount. But if there's more room 1" or so (mine has 1 & 1/4" space) then its in the V8 mount. Dont really know if what I was told is true or not, that thread I would have to dig a little bit to find the person that posted that.
#18 |
#19 |
#20 |
#21 |
#22 | |
![]() Yes...I use the clips at the bottom.
#23 | |
The first two lines of #1 post/drawing said it being the truck is a 68 C10 I6 3ott. V8 sbc/700R4 NOW. You must of missed the (now). I wasnt getting smart or snippy with my words ( understand now), I guess it could be understood as so, Marvin |
#24 |
I must have missed the reason why you would have to apologize, I must be too thick skinned. don't sweat the small stuff, Joe
#25 |
I guess other than yours in the past (some where in time) I have used some strong wording that didnt take well with Liz from our board members area. Just wanting to clear the air if needed, I as well am thick skinned, I guess you & me are the only ones wearing our big boy pants LOL, just saying
