5 Lug Conversion
I swapped the front of my 69 over to 5 lug no problems at all now I am going to do the rear.I was told to get axles out of a 71 up and they would work.They are about3/4" to long on each side are the backing plates the same disc versus drums what am I missing here?Does any one know if the axles are the same from a 74 Your help is mucho appreciated once again
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327/4L60 |
I don't know if the 74 axles are the same, but I used the longer axles (from a 71, I think). There was about 9/16" of a gap. The shoulder for the bearing was long enough on the axle, however. I found that a 74 drum closed the gap perfectly between the 69 backplate with the longer axles. This drum is for a 2-3/4" pad, but I have the 2" pads on the 69 backplate. There is a picture of it on my website....
http://www.classicplace.com/truck2.html Greg
69 SWB LT1/4L60E www.classicplace.com |
#3 | |
Keepin an eye out
Re: 5 Lug Conversion
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
Thankyou
ttt for the input and looks like a sweet truck you got minibike.My drums are like 2 1/2" wide where the shoe rides so I don't know what t do guess I'll make a 3/4" spacer to get it close
