Old 09-02-2015, 05:38 PM   #1
softballnrd27
Always a work in progress
softballnrd27's Avatar
Rear suspension
73 C10 SWB
What would be the better all around performing rear suspension?
4 Link or truck arm both W/coilovers.
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 09-03-2015, 07:21 AM   #2
biketopia
Re: Rear suspension
NASCAR to this day still uses the trailing arm suspension, if it's good enough for NASCAR it's good enough for me. I'm going with trailing arms and coilovers when I pull the trigger.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
Old 09-03-2015, 09:46 AM   #3
andrewmp6
Re: Rear suspension
All around the truck arms,Drag racing 4 link,Road racing 4 link or a 3 link depends who you ask.
andrewmp6 is offline   Reply With Quote
Old 09-03-2015, 01:36 PM   #4
69gmcc10
69gmcc10's Avatar
Re: Rear suspension
They are both good systems. the 4 link has the potential, depending on features, for allot of adjustments for fine tuning of the suspension to get exactly what you want, but with all the extra moving parts and adjust-ability can be more complicated. the truck arm is a simple and proven system, but does lack in some areas when it comes to making adjustments.
Allot of companies make 4 link systems for your truck and I know Porterbuilt makes a truck arm kit for the square body trucks. Good luck and let us know what you choose and why.
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676
03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582
69gmcc10 is offline   Reply With Quote
Old 09-04-2015, 01:21 PM   #5
bluex
bluex's Avatar
Re: Rear suspension
CPP has a truck arm conversion for the squarebody as well. I have no experience with it but based off my experience so far with my porterbuilt kit I'd say go CPP if you want truck arms on a square. That or make the square fit a factory trailing arm frame, either would be easier probably...
bluex is offline   Reply With Quote
Old 09-08-2015, 07:06 AM   #6
biketopia
Re: Rear suspension
bluex have you had issues with your porterbuilt stuff??
Old 09-09-2015, 12:20 PM   #7
bluex
bluex's Avatar
Re: Rear suspension
With the square body trailing arm conversion, yes. Several issues in fact and I'm not the only one....
Old 09-09-2015, 12:52 PM   #8
PBFAB.COM
PBFAB.COM's Avatar
Re: Rear suspension
The main challenge was being able to find and determine the frame rail variances that exist on the 73-87 frames. Unfortunately there are a couple of differences from driver side to passenger side depending on the CAT or no CAT options. It led to some fitment issues on the trailing arm crossmember that caused a few headaches along the way.
We don't sell very many of these kits, so it took a little while to find the main discrepancies. The truck that we originally proto-typed the kit on turned out to be the least common.... go figure!
Nate
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
