09-15-2015, 06:36 PM | #1 |
50-54 door weatherstrip
So I think I have this weatherstrip installed correctly but there is no way I can shut the door hard enough to compress the seal.... what am I doing wrong?
09-16-2015, 03:42 AM | #2 |
Re: 50-54 door weatherstrip
no, that is installed wrong. with that said.... I still had to cut my trim in half to get the doors to close properly. I don't think the pre 50s trucks should use that style rubber, but that is what all of the vendors sell. I ended up using house door rubber from Home Depot on one of my doors (on the edge where the hinges are..... it was way to close and tight otherwise.
09-16-2015, 09:51 AM | #3 |
There is a good video on youtube about installing that
09-17-2015, 12:39 PM | #4 |
I think you have it right but it's hard to tell from the pic. I had the same problem and ordered new weatherstrip from Metro Weatherstripping
Part# LP 40-A it says for a lighter seal. It worked perfect and they will send you a small sample for free if needed. The only problem is the price, it's sold by the foot and cost me $100+. Steele rubber has a similar product but I don"t remember the part# |
09-17-2015, 03:01 PM | #5 |
Thanks guys I will check into the seals.... anyone have a good picture of the correct direction of installation. I found the video on youtube and it just says the long side should point toward the cab???
