Old 09-26-2015, 05:27 PM   #1
dfrank
dfrank's Avatar
81-87 Bench Seat Replacement Foam?
My 86 K10 needs the seat re-done cause the foam is shot. All I can find is replacement lower foam for the bench seat. Does anybody know where I can find the upper replacement foam? I can find the upper foam for a 73-80 but not for an 81-87. Thanks, David!
dfrank is offline   Reply With Quote
Old 09-26-2015, 05:57 PM   #2
NtheFamily
NtheFamily's Avatar
Re: 81-87 Bench Replacement Foam?
LMC sells them.
'65 Chevy Fleetside
'85 Chevy 4x4
'92 Chevy s10
NtheFamily is offline   Reply With Quote
Old 09-26-2015, 05:58 PM   #3
UKNOWME
UKNOWME's Avatar
Look at the part numbers. Only the bottom for 81-87.
I always thought they were the same. That's weird that no one makes them.
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 09-26-2015, 06:02 PM   #4
NtheFamily
NtheFamily's Avatar
I didn't notice that. Sorry for the misinformation. They must have quit selling the back because my dad had bought a set several several years ago.
'65 Chevy Fleetside
'85 Chevy 4x4
'92 Chevy s10
Old 09-26-2015, 07:04 PM   #5
dfrank
dfrank's Avatar
No, problem I didn't see it at first either. I actually almost ordered the set then I saw it was only for 73-80.
Old 09-26-2015, 07:15 PM   #6
tucsonjwt
Have you checked with your local upholstery shops? They should be able to rebuild your seat bottom and back and make it look like new. I had my upholsterer use thicker and denser foam in my seat rebuild to help it last longer.
I only needed a seat bottom rebuild but the whole job with re upholstery was about $210. it looks as good as new to me - upholstery is very close to OEM.
tucsonjwt is offline   Reply With Quote
Old 09-26-2015, 07:40 PM   #7
dfrank
dfrank's Avatar
There is a guy local who I was going to have re-do the seat for me when I completely restore the truck. With the material and everything I picked the price comes to around $500. I may just have him beef up the foam in the spots that need it for now until we get the new building done and I can tear the truck apart and start the process.
Old 09-26-2015, 07:52 PM   #8
UKNOWME
UKNOWME's Avatar
Does anyone know what the difference is between the 2 for the upper foam?
1964 Chevy c10
Old 09-27-2015, 01:07 PM   #9
tucsonjwt
Just going from memory, but I think my 73 and 76 seat backs had a more tapered edge on the top and was a little thinner than my 83. Early seats also did not tilt forward.
I think my upholsterer just cut out and replaced the driver's butt worn out area of my seat and then covered the whole thing with another layer of thicker, denser foam to even things out. Really, you can't tell it from factory and it seems a lot firmer and stronger than OEM.
Good auto upholsterers do this all day long and can knock out a rebuilt seat in a few hours. Around here a seat can be rebuilt and recovered for a few hundred dollars, but labor is cheap since we are close to the border and there is a lot of competition.
If you are a stickler for factory show quality OEM and count the stitches on the fabric, then that is a whole different story.
