Old 09-29-2015, 06:31 PM   #1
freak
bracket for clutch pedal?
I'm going to swap a t56 into my 72 in place of the auto. What do I need to get a clutch pedal in it? Do I need to replace the bracket that holds the brake pedal with one from a manual truck?
freak is offline   Reply With Quote
Old 09-29-2015, 07:44 PM   #2
hugger6933
Re: bracket for clutch pedal?
You should't have to change out too much cause there never was a big brake pedal for the auto. They were all the same in both types of truck. that is an upgrade I'm doing to mine that are autos, putting in a bigger brake pedal. Jim
hugger6933 is offline   Reply With Quote
Old 09-29-2015, 09:27 PM   #3
57taskforce
All about them K’s
57taskforce's Avatar
All you need is a clutch pedal and linkage or captainfab on the parts board makes some pretty cool hydraulic clutch parts as well. The pedal will slide directly into the auto brake pedal assembly.
Tyler
57taskforce is offline   Reply With Quote
Old 09-29-2015, 09:51 PM   #4
FirstOwner69
FirstOwner69's Avatar
There is also a rectangular hole on the brake pedal bracket to mount a rubber bumper for the clutch pedal. It's like the bumper for the brake pedal.
FirstOwner69 is offline   Reply With Quote
Old 11-25-2015, 08:05 PM   #5
Goffer
Goffer's Avatar
I'm getting the ball rolling on a tko600 swap in a '71 C10 and am looking for the clutch pedal, linkage and any other goodies I may need.
'71 C10 swb 350sb/700r4
Goffer is offline   Reply With Quote
Old 11-25-2015, 11:04 PM   #6
LockDoc
The Older Generation
LockDoc's Avatar
This is an older post but it shows the parts you will need.
http://67-72chevytrucks.com/vboard/s...d.php?t=585023
The pedal and shaft will install into your existing assembly....
LockDoc
Leon
