Old 10-18-2015, 04:46 PM   #1
sleepy350
Drop spring hanger help
Hey guys working on my Dad's 74 today installing drop spring hangers. Got the old hangers out but ran into a snag when installing the new ones. On the hangers my dad got (I believe they're from Western Chassis) the bolt holes don't quite line up. I can get two to line up but with two lined up the other two factory holes are about 1/8" - 1/4" off. Do you guys think this is something that would be safe to just oval out with a file? Factory comes with 4 rivets; if I were to oval out the holes with the new hangars there would be six bolts, two of which would be oval-ed out so I can get them to line up. If it were my truck I would just do it but seeing as it's my Dad's and he plans on driving a lot I just want to make sure it's safe. Pics below:
Thanks in advance!
-Angelo
sleepy350 is offline   Reply With Quote
Old 10-19-2015, 07:36 AM   #2
RodsGreen10
RodsGreen10's Avatar
Re: Drop spring hanger help
Should look like this. These are my WC 2" lowering hangers installed. the holes "the spots the rivets had been" lined up on my frame and I had to drill 2 additional holes for the bolts.
RodsGreen10 is offline   Reply With Quote
Old 10-19-2015, 07:39 AM   #3
Desert1957
Desert1957's Avatar
I think OP is showing the two mounts together to compare bolt hole differences.
Desert
Desert1957 is offline   Reply With Quote
Old 10-19-2015, 08:17 AM   #4
Jake Wade
Jake Wade's Avatar
Looks like a manufacturing flaw.
Jake Wade is offline   Reply With Quote
Old 10-19-2015, 08:45 AM   #5
RodsGreen10
Does the WC hanger sit flush on the back?
Old 10-19-2015, 08:15 PM   #6
jetmech85
You could try clamping the new hangers to the frame and do not align the two holes with bolts but instead see if you could align all holes with minimum mismatch. Are you going to drill two new holes to match the new holes on the hangers? If so, then these fresh holes could be drilled and bolted to hold the hangers where they will not move while you drill/ream the misaligned holes to the next larger size thereby possibly cleaning the elongation to make a round hole.
jetmech85 is offline   Reply With Quote
Old 10-20-2015, 04:22 PM   #7
1970pelle
1970pelle's Avatar
If you do decide to go with these brackets. Following the advice already given, I would go one step further and use a larger bolt in the affected holes.
Ken
1985 IROC Z28 190HP TPI 305,700r4,T-tops,rear trac lock, Black on lite gray, 16in Z28 wheels
2007 Lexus ES350 (wifes)
1984 CJ7 with 1995 HO4.0L MPI, 2 1/2 OME YJ Lift
“There is no limit to the amount of good you can do if you don't care who gets the credit.”
― Ronald Reagan
1970pelle is offline   Reply With Quote
lowering kit, springs
