TH350 1 pc driveshaft question
I currently have a 700R4 in my truck that is on its last leg. A buddy has a TH350 I can pick up cheap. Last time i did this I used the driveshaft out of my 65 chevelle but never measured it and that car is long gone. Does anyone have the measurement?
BTW, before anyone asks why I`m going to a th350, its only temporary. This is my only vehicle so I need to put the th350 in while I have the 700r4 rebuilt then swap back. A lot of work yes, but since its my daily I have to do what I have to to get by.
Anthony |
Re: TH350 1 pc driveshaft question
If you have a short tail th350 and it should be fine using your original driveshaft if I remember correctly. If you go from a long tail to a short it won't work. But i could be wrong...I read it somewhere just would have to search the forums again
Th 350 and 700r4 are different lengths so I don't see how the driveshaft would be the same length for both transmissions.
Anthony |
Just found my source. If you have a long tail th350 you can use the original driveshaft on the 700r4
Good deal. My 292nd gear in my th350 went out so I may go with the 700r4 here soon
When I did my 700r4 to th350 swap I used a long tailshaft (9-1/4") th350 and my original one piece driveshaft. You can figure out the difference when you get your donor th350 and measure its tailshaft.
Alex. |
Thanks for the input guys. Helpfull info. I'm not sure what tail shafts it is but I'm guessing it's a short shaft. I haven't looked at it yet. I need to have everything ready to go before I do the swap because this is my only vehicle and I won't be able to have any down time. I can do the swap in less than a day so it's a weekend project.
Anthony |
Center to center of u-joints is 55 1/4" on my 1985 C/10 with factory installed 350 trans. Note that my trans is a long tail.
Tony Nicholas @ Midwest Metal Masters 1953 Chevy 3100 392 Hemi w/727 & 9” Ford 1985 Chevy C/10 6.0L 4L80 373 locker |
So for a 6" short tail shaft I`m guessing I`d need a 58 1/4" shaft? My trans went out last night so I`ve got to get this swapped over the weekend and I cant find a trusted 700R4 anywhere. I just cant spend $500 on a used one and hope that it works. I know this Th350 works and its free.
Anthony |
Sounds about right.
About to start the swap. I`m going to get the TH350 in there and then take a measurement. I did several searches and came up with several different measurements for the same 117" wheel base trucks. We`ll see how it goes.
Anthony |
