Old 10-26-2015, 12:13 PM   #1
gmebey
Need some help with power steering pulley and brackets
This is kind of a mess, so here we go…..
Sometime during the life of my truck there was engine swap with the donor being 1975 vette, plus at some point someone added power steering. The pump pulley is not proper aligned and it appears to me that the brackets are not the correct ones for this engine.
Please take a look at the pictures and provide ideas of how to fix this.
gmebey is offline   Reply With Quote
Old 10-26-2015, 01:09 PM   #2
CSmittyMetalworks
Re: Need some help with power steering pulley and brackets
After several hours (and several purchases of brackets) at the salvage yard looking for parts to convert my '69 C15 to power steering, I found purchasing an aftermarket bracket to be the best course. Wound up with the March Performance Power Steering Brackets #20112
Worked well and looks good. There is a spacer/collar that should go from the top tab into the head of your current set-up.
CSmittyMetalworks is offline   Reply With Quote
Old 10-26-2015, 02:41 PM   #3
Jrainman
Jrainman's Avatar
I think the power steering bracket you are using should be mounted lower , I believe the holes in the block you are using now is for a driver side ALT set up , I never saw a GM power steering pump set up high like that
I could be wrong but something to look in to.
Jrainman is offline   Reply With Quote
Old 10-26-2015, 03:14 PM   #4
gmebey
I suspect that the PS pump I have is from a 305 with a short water pump, and that someone rigged it to work with the long water pump that is on the engine. I forgot to mention that only one grove is used (ie only one belt) on this setup.
Can any provide pictures of a factor setup for a 69-71 350 CID?
Old 10-26-2015, 08:43 PM   #5
swamp rat
swamp rat's Avatar
Definantly not a V-8 power steering bracket, V-8 brackets mounts low on the block not to the head and manifold. I'd scan the junk yards for a short waterpump equiped power steering bracket.
Not the best pic but in the middle pic you can see how low the stock mount is in comparason.
http://67-72chevytrucks.com/vboard/s...&postcount=317
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 10-26-2015, 09:12 PM   #6
Money_pit
Money_pit's Avatar
Newer Saginaw pump supposed to be a two belt system. One belt for alt,water pump and crank. Second belt goes from crank to ps pump. Had similar setup on an 79 Malibu with a small block it had an actual steel spacer in there. I think that is another completely different bracket hooked the exhaust manifold stud as well. Do a search for Alan grove components tons of brackets for anything there.
71 C10 Finally took a leap and did the 5.3 4l80e swap.
Running the Holley Terminator Xmax. Still working bugs out.
Money_pit is offline   Reply With Quote
Old 10-27-2015, 11:11 PM   #7
gmebey
Update.
I took the advice of Money Pit and contacted Alan grove components. Long story short my setup is a "hodge podge". They were a great help and recommended that I get pictures of my PS pump to help select the correct bracket kit.......
Unfortunately my pump doesn't have the rear mounting holes. So now I'm searching for a pump..... At this time I have a lot more questions than answers.
Basically what pump do I need for a setup w/o AC..... Any Suggestions of model number and source to getting a new pump?
Thanks in advance,
Gerald
Old 10-28-2015, 11:06 AM   #8
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
My stock power steering bracket on the 350 in my 1972 GMC bolts to the top left engine mount.
Just get a power steering pump for the year of your truck.
Also I noticed you have a snapped off bolt in one of the cylinder head holes on the drivers side.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 10-28-2015, 11:13 AM   #9
Jrainman
Jrainman's Avatar
Ok so here is a exploded view of a 1975 corvette power steering pump and bracket assembly picture, the pump is a Saginaw part number is 6178 b and the bracket part number for summit racing is TFF-6504A
Now on a side note you will have to figure out what gear box you have and make or find the pressure line , the return line is kind of universal to a degree.
Old 10-28-2015, 02:51 PM   #10
CSmittyMetalworks
The weather has been a bit crappy out so I just got around to snapping a pic of my set-up. The lines are a bit jacked up because I bought the wrong pressure line. The next one will go under the pump. Finding everything I needed was a pain, even stuff I bought new. I'm pretty happy with this mount and doesn't look half bad. Sad thing is, right now, it looks like lipstick on a pig.
Old 10-28-2015, 03:34 PM   #11
Myoldtruck
Myoldtruck's Avatar
csmitty, whos bracket are you using. Where did you get it from. Im about to go to power steering also and need the mounting bracket.
Myoldtruck is offline   Reply With Quote
Old 10-28-2015, 06:22 PM   #12
gmebey
I'm looking at using the Alan Grove 402L bracket set for my PS pump. Unfortunately I will need to get a replacement pump since mine doesn't have the rear mounting holes.
As Gary notice I do have a bolt snapped off in the head.....and my guess it's really stuck! Which I think the bolt is the root cause of why my PS pump is mounted so weird.
Old 10-28-2015, 07:49 PM   #13
CSmittyMetalworks
I got it from Summit, but it can also be ordered straight from the manufacture, March Performance. They have brackets for power steering w/ short and long pumps, for the R or L, as well as alternators.
http://www.summitracing.com/search/b...ibanner=SREPD5
The biggest problem I had was finding the right belt that would get tight before the pump began touching the frame. Once I got it worked out, I haven't touched it since. Wish all the issues on her were that easy to fix. After going to the yard and getting parts, I found I could have ordered the steering box, pump and brackets for less than $300 thru Summit. Oh well.
Old 10-28-2015, 07:59 PM   #14
CSmittyMetalworks
Here are just a few of the brackets I tried to use. Some are GM metric and some are Chevy SB 1 gen.
