Old 10-28-2015, 04:11 PM   #1
daveklein
Distributor
I have a 67 with the 250 6 cyl.....I put a new vacuum line from carb to dist. and that is OK but the line connection at the distributor comes out facing straight forward and was difficult to connect hose, (radiator hose,,timing chain cover in the way).....Is that normal or was my distributor lined up wrong....It runs good the way it is but I will change it next tune if it's not quite right...
Thanks,,Dave A picure of correct pointing direction would be nice...
daveklein is offline   Reply With Quote
