Old 10-30-2015, 08:38 PM   #1
aotte1
Does Anything Bolt Here on Frame Cross Member?
On my 1964 K10, their are two square holes in frame cross member, does anything bolt or attach to these holes. Photo below.
thanks,
Les
aotte1 is offline   Reply With Quote
Old 10-30-2015, 09:00 PM   #2
jdl71
jdl71's Avatar
Re: Does Anything Bolt Here on Frame Cross Member?
If I am looking at that picture correctly that is where the lower rad mounts go on a 6 cyl.
Psalm 23
64 C10
66 K20
jdl71 is offline   Reply With Quote
Old 10-30-2015, 11:25 PM   #3
aotte1
JDL71,
Thanks, here are a couple more photos.
It is the square hole, where you could insert a carriage bolt.
Note: The extra bracket below the frame cross member in some of the photos, are brackets being adding to mount the front of '78 sway bar. The photos are of a 1964 K10.
Les
Old 10-31-2015, 12:55 AM   #4
Captainfab
60-66 Nut
As jdl71 said, that is where the saddles for the small 6cyl radiator mount.
Old 10-31-2015, 09:48 AM   #5
aotte1
Thanks for confirming "captain" what jdl71 said.
Follow-up question, were they welded in?
Thanks,
Les
Old 10-31-2015, 03:20 PM   #6
jdl71
jdl71's Avatar
They are riveted. I changed to a larger radiator and used the forward mount, but did not remove the others:
Are you wanting to use those holes for something or? Just curious.
Psalm 23
64 C10
66 K20
Old 10-31-2015, 08:57 PM   #7
aotte1
jdl71,
I want to use the 6 cyl holes for something else. Bolt '78 front sway bar (SB) brackets in the holes. Photos below shows that I need to add a strap to the bracket to connect it to frame on one end. First photo shows the straps that will be bent and attached to 6 cyl saddle mounting hole.
Les
Old 11-01-2015, 05:00 PM   #8
jdl71
jdl71's Avatar
It seemed to me like that cross member was pretty flimsy and thin. Might be different in the K series though.
Psalm 23
64 C10
66 K20
Old 11-01-2015, 09:26 PM   #9
aotte1
kdl71,
The 1964 K10 frame cross member is not as thick as the main longitudinal frame member, however, it is just a little thinner then the '73 to '87 K10 cross member. Seems pretty strong.
The bracket is bolted to the frame with two bolts on one side, and to the cross member with one. It would seem from the design of the bracket that the longitudinal frame connection take most of the load. The bracket itself is very thick/strong.
Les
Old 11-01-2015, 10:13 PM   #10
jdl71
jdl71's Avatar
Good to hear. Hope it works for you.
Psalm 23
64 C10
66 K20
