Old 11-11-2015, 05:57 PM   #1
merlin3
post pictures of belts
i wonder if you guys could post pictures of your big block fan,alt.and power steering belt routing.when i first start my truck and at high RPMS the fan belt squeaks i can grab the fan and turn it with little effort.I enclosed some pictures of my setup but i am not sure if i got it right.1972 c10 509 Merlin 3 no ac.thanks for the help.the power steering belt looks crooked in the image but it is not,do i need one more belt?
merlin3 is offline   Reply With Quote
Old 11-11-2015, 06:37 PM   #2
whiskey_marc
whiskey_marc's Avatar
Re: post pictures of belts
Looks like your power steering belt and alternator aren't aligned properly, get a pulley remover, line up your power steering belt, and adjust your alternator then give that a shot. Slight chance you also have the belt a bit too tight as well.
Last edited by whiskey_marc; 11-11-2015 at 06:39 PM. Reason: Caught more in the picture after posting
whiskey_marc is offline   Reply With Quote
Old 11-11-2015, 06:56 PM   #3
merlin3
thanks Whisky Mark,the belts are lined up it just looks that way in the image and i tried all different tensions on the belts.
Old 11-11-2015, 07:16 PM   #4
northern
northern's Avatar
Your P/S belt is not in alignment.
northern is offline   Reply With Quote
Old 11-12-2015, 01:02 AM   #5
swamp rat
swamp rat's Avatar
I can see that the pic is not centered up on the P.S belts so i'll take your word on its alignmenmt, the alternator looks like its front is dropped down a little from what i can tell by turning my head sideways... Usually the pully with the least amount of contact is the culpret, ie water pump pulley.
The squeal i get (sbc350) has always been the alternator belt, no matter how much i try to align, new belts different pulleys, different mount bracket, i still get a little squeal.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 11-12-2015, 05:37 AM   #6
merlin3
thanks for pointing out the alternator i never noticed that,i guess i will try a serpentine kit.
Old 11-12-2015, 06:07 AM   #7
roboticjunky
IMO
Base on your pic, your P/S pulley isn't aligned right. If you look at your pic where your harmonic balancer says 30, go straight down in that pic. You'll see that your belt is bending back because your P/S pulley is back far than the harmonic balancer pulley.
roboticjunky is offline   Reply With Quote
