Old 11-14-2015, 05:08 PM   #1
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Door panels removed, observations and as usual, question or two
71 Chevy Deluxe
Appreciate the help I received earlier. That common "fork" tool for handle/crank removal makes it a breeze.
Can't say I'm disappointed with the condition of the panels nor the trim they insert into. Nope, not one bit. Of course the paper "chrome" is flaking off, which surrounds the wood grain..........So that brings me to my first question, what are some good ideas for how to deal with this?
There's just one 1" tear on the bottom edge of the LH panel. I figure any black sealant will do. Suggestions appreciated.
The second image of the LH door shows a foam rubber seal for behind the door panel. It's not on the RH door and go figure, the LH panel isn't quite as flat as the RH panel. What's the deal with the seal on the LH door, but not the RH door? The LH panel may have been removed once before, because it's missing two washers for the screws for the bottom of the panel. Missing hardware appears to be a common theme on the interior of this truck.
Thank you.
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C
I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too.
Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc.
The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.
Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is online now   Reply With Quote
