11-30-2015, 11:39 AM | #1 |
68 trailing arms
I have a 68 BB and notice 1 trailing arm has at least a 1/8 gap between the rails and the other looks new. Should I make a change or squeeze together and weld?
Tom in Iowa 68 L88 C10 68 4x4 C10 soon |
11-30-2015, 12:04 PM | #2 |
motor exploder
Re: 68 trailing arms
Sounds like a job for a C-clamp & a welder. I stitch welded my arms together when I restored my truck, as they were starting to do the same thing.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
11-30-2015, 01:02 PM | #3 |
The Older Generation
The correct way is to drill out the spot welds and take it apart to get all of the rust out, then weld it back together. It will look factory then. LockDoc
