Stylin
Edelbrock carb/intake combo
ok im getting the crate 350 gm engine in a week or so and i was wondering how good of gas mileage i would get with a 600cfm edelbrock performer series carb and say either a edelbrock performer or performer rpm manifold. im goin for gas mileage till i repay my loan then ill add more performance parts
. or if anyone has a really good suggestion on a carb/intake combo for gas mileage i would appreciate suggestions.
Ive been traveling for some time, with my fishin pole and my bottle of shyne. Most Girls like finished products and just dont understand what a good addiction does for you http://www.paulwall.us/ |
The 600/Performer combo is a great combo for gas mileage and daily driveability. It depends on a lot more than that though. How big of a cam does it have? (Just stock I assume)
Depends on what tranny you have and what your rear gears are and what your tire size is...here's my stats 650/Performer/SMALL Cam TH350/4.11's/28" Tire 10mpg. (But this 10mpg has been attained via me tuning the PISS outta the carb with my Wideband Oxygen Sensor. Now, when I'm idling or cruiseing I'm at a perfect 14.5:1, which unless you have a wideband, you will never get dead on.) BTW: Are you getting the "GoodWrench 350" Crate motor for $1300? If you are, that's basically the motor I have, with a bit more compression and bore. Last edited by TIMSPEED; 09-17-2003 at 02:40 AM. |
Stylin
yea im getting the gm goodwrench 350 crate engine for 1300, possibly the kit for 1800 which is a performer intake and a 625cfm carter carb, malory hei dist. and chrome valve covers.my stats are, th350/dont know the rear end gears/and stock size tires.(sometime i want to goto a 700r4 with 4.11 gears)
Stylin
255/70 R15's
Hmm, if you don't already have a carb or intake, then the kit for $1800 would be a good deal. Is that assembled all together? A Carter Carb is Edelbrock now...with the warranty on that motor it makes it a good deal for a nice driver.
Stylin
everything is shipped seperate
That's the motor I am using. I did change the cam out before I put it in. You may want to go with the Performer EPS, they say it produces a little more horsepower. I'm satisfied with mine....for now.
Gary -1986 SWB: lowered 4/6, SOLD!!! -Best 1/4 mile: 14.51 @ 91.01 MPH -2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!! -2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels |
I'm back with 2nd truck!
I've got the ZZ4 on mine with the Performer RPM like intake that came with it and a Edelbrock 600 on it. With my setup I get 13-14 miles a gallon.
1979 Chevrolet Bonanza Big10 "Tootsie Roll" 1985 Chevrolet Silverado (wife's) Member of the Southern Bowties Club "Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson Last edited by 79BIG10; 09-17-2003 at 01:35 PM. |
Project92 SWB stepside
I would pass on the performer intake. It is no better power wise or MPG wise as a stock piece. It is just made as a alternative to stock parts for everday drivers. At least get the rpm intake.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448 |
Stylin
ok so i decided to go with the edel. performer eps intake, the 600cfm performer carb elec. choke, the fuel line kit, and a wood 1" spacer. i also went ahead and picked up a accell high performance hei replacement dist. , moroso blue max spiral core plug wires, and the moroso wire loom kit. all this came to 675.52 from jegs.
| Bookmarks |
