Old 12-09-2015, 09:34 PM   #1
zach_carver
zach_carver's Avatar
Electric Fan Options
Ok ls swappers I got some questions, 1965 C10 getting a LS2 put in. Plan to use my aluminum radiator that was used with the old sb due to it not even bring a year old. What is my least expensive set up for electric fans? Read some places 2 12" fans in the radiator with no shroud. Just looking for some insight. Thanks guys
1965 C10 LS2/4l70, WHITE, 5/7 DROP
LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283
1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E
1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE
zach_carver is offline   Reply With Quote
Old 12-09-2015, 10:10 PM   #2
aknovaman
Re: Electric Fan Options
What ever you don't put those stupid zip ties through the radiator core. They get loose and vibrate till they wear through the cooling tubes. Ebay sells 16 inch fans or you can get a affordable set of new or used Ford Taurus or 96-02 Camaro fans that will be more than adequate.
Current project 1959 Willys = GEZR TRUK
Geezer is a Latin compound word made up of two roots.
Gee meaning Urine Stain and Zer meaning your pants are open!
FMCDH GBU and GBA
http://www.youtube.com/user/aknovaman/videos
aknovaman is offline   Reply With Quote
Old 12-09-2015, 10:54 PM   #3
zach_carver
Any idea what year Ford Taurus fans I need? Will both of those mount up around my radiator?
Old 12-10-2015, 12:30 AM   #4
aknovaman
Google them or go to pick a part salvage. Likely 2000-ish years.
FMCDH GBU and GBA
Old 12-10-2015, 08:25 AM   #5
zach_carver
Thanks man!
Old 12-10-2015, 09:24 AM   #6
Wasted Income
Boosted Member
Wasted Income's Avatar
Dodge Intrepid fans are outstanding. Cheap, good shroud, and sized to fit a truck radiator pretty well.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 12-10-2015, 09:44 AM   #7
LeesTruk
Ford Windstar fans also work ( shown here on my '80 C10 radiator )
So will '06 and later Impala fans (Police option or 5.3L)
LeesTruk is offline   Reply With Quote
Old 12-10-2015, 10:40 AM   #8
solidaxel
solidaxel's Avatar
I have been using Mopar fans on all of my V-8 conversions
Take a look at the Jeep fans
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 12-10-2015, 10:44 AM   #9
aknovaman
Grand Cherokee fans draw a butt load of current at startup and when running so you better run some 10 guage wire and a heavy duty relay. They burn up some gm weather pack relays.
FMCDH GBU and GBA
Old 12-10-2015, 10:53 AM   #10
Wasted Income
Boosted Member
Yea, these Intrepid fans do draw some amps. But, they also move a LOT of air.
I just welded some bosses to my radiator to mount them. I've done this on 4 builds, all with awesome results.
Turbo diesel
Old 12-10-2015, 10:57 AM   #11
aknovaman
Intrepid is much less amp loads than the grand Cherokee.
FMCDH GBU and GBA
Old 12-10-2015, 11:05 AM   #12
Wasted Income
Boosted Member
Pro Tip:
If going with Intrepid fans, skip the junkyard and go to Rock Auto. $100 brand new.
Turbo diesel
Old 12-10-2015, 11:06 AM   #13
americanmusc1e
americanmusc1e's Avatar
I have a fan/shroud setup off of a Nissan altima that fits just great on my factory 4-row radiator. I think it's off of a 98-01 Altima 4cyl. $70 on ebay. There used to be a write up on here about it.
Edit.. found it http://67-72chevytrucks.com/vboard/s...ad.php?t=50085
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline   Reply With Quote
Old 12-10-2015, 11:08 AM   #14
aknovaman
Rock auto !
Bingo !
FMCDH GBU and GBA
Old 12-10-2015, 11:18 AM   #15
zach_carver
Ive looked on rockauto at the fbody fans. New dorman shroud fans all $124 bucks. Not to bad i didnt think. Just wondering if anyone had mounted them on my style radiator. Since im not able to weld anything ill have to find a way to mount where factory shroud went.
