Old 12-10-2015, 09:29 PM   #1
softballnrd27
Always a work in progress
softballnrd27's Avatar
Cab Insulation plan
I have ordered some Al's Liner Heat and Noise, and some POR-15 to coat the floor and the underside of the new cab. What else should I get in order to insulate and deaden the sound? I will order jute and carpet later on, I am just working on rust prevention and wiring right now.
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 12-10-2015, 11:12 PM   #2
tommy217xxx
tommy217xxx's Avatar
Re: Cab Insulation plan
I had the Same question. I think I'm gonna us dynomat in mine b/c my mufflers come out right behind the cab and it's a bit noisy.
TJ
76 gmc 1500 swb patina finish
Dropped 4/5, 350/4 speed
80 Chevy c10 lwb
305/350
tommy217xxx is offline   Reply With Quote
Old 12-11-2015, 12:40 AM   #3
UKNOWME
UKNOWME's Avatar
My local audio shop used dynomat on the whole floor and back wall. My exhaust dumps under the cab and I have no issues at all. I'd personally skip the POR 15 inside unless you have a rust issue.
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 12-11-2015, 02:35 AM   #4
NJ C10 Guy
www.sounddeadenershowdown.com
All the info you need is right there.
NJ C10 Guy is offline   Reply With Quote
Old 12-11-2015, 07:49 AM   #5
Jake Wade
Jake Wade's Avatar
The dyno mat type products do very little to dampen stuff like engine/road/exhaust noise. They do a good job of taking rattles and metal creaking out.
In addition to dynomat style products, you need a closed cell foam type product along with a product like luxury liner on top of that.
It can get expensive.
Jake Wade is offline   Reply With Quote
Old 12-11-2015, 11:15 AM   #6
NJ C10 Guy
If you don't want to click on the link then here is what you need, in this order:
1. Sound deadener tiles. Not to line the entire cab with, but strategically place throughout to reduce vibrations.
2. Closed cell foam. Acts as a decoupler, no sound deadening qualities.
3. Mass loaded vinyl. This will reduce noise.
4. Carpet. Jute padding not needed, but will not hurt either.
There are other products you can use, but a lot of people overkill with the sound deadener. It reduces vibrations but does not make your truck soundproof so to speak.
Old 12-11-2015, 11:24 AM   #7
SCOTI
SCOTI's Avatar
x2.
Sound deadener for rattles/vibrations (Boom Mat/Dynomat/etc).
Foam layer for isolation.
MLV as a barrier that keeps the sounds out.
Carpet w/the jute pad removed where necessary for installation.
This is what I did for my dually. It has a big block, 1 3/4" full length headers, & 3" exhaust through the mufflers under the cab. When you're sitting inside, it's very quiet. The MLV I got has the vinyl/foam bonded together for an easier install. It was a PITA getting things bolted down (seats, seat belts, etc) but worth it IMO.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 12-11-2015, 05:32 PM   #8
Jrgunn5150
Mine is Chassis Saver/Dynamat/Closed Cell foam/ Rubber floor mat. It's only half done, so I can't speeak to it's effectiveness yet.
I did the floor up to the seam, back up to the rear window. I did the headliner, and inside the doors also.
J.R.
Link to Daryl's build, http://67-72chevytrucks.com/vboard/s...10#post8443010
Link to my Youtube channel with build info, https://www.youtube.com/thedrivewayengineer
Jrgunn5150 is offline   Reply With Quote
Old 12-11-2015, 06:34 PM   #9
softballnrd27
I have some surface rust in the cab that doesn't warrant replacement but I want to stop the rust. I should have clarified that first.
Is the peel and stick stuff like fatmat/dynomat used only for "spot" treatment to lessen vibration?
Do I cover the whole floor with closed cell foam?
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 12-11-2015, 07:18 PM   #10
SCOTI
SCOTI's Avatar
The peel & stick stuff does not require 100% coverage to be effective. Each product prob differs depending on it's density so I would follow mfr's recommendations. Some guys do go w/100% coverage but it's just spending alot more for minimal (if any) gain.
Yes on the closed cell foam. I even added it where my speakers were & behind the door panels.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-11-2015, 11:23 PM   #11
Jrgunn5150
Correct, however I went with 100% coverage just because I wanted additional heat insulation.
J.R.
Old 12-12-2015, 03:29 AM   #12
esbstuff
Following...
esbstuff is offline   Reply With Quote
Old 12-13-2015, 02:48 PM   #13
softballnrd27
Thanks guys, I should start on it again next weekend. Most of my weekends are spent hunting and that is winding down so now I have time again.
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 12-14-2015, 12:11 PM   #14
CSHADES
CSHADES's Avatar
I am doing a cab for my 77 GMC plow truck right now. I am going to use an epoxy primer, then spray Lizard skin, both the sound deadner and the heat insulation. I used the Lizard Skin in my 63 Nova when I redid it and it made a world of difference heat and noise wise. I am not going to use any carpet or floor mats in the truck to try to keep the floor from getting wet and holding all the wet under a floor mat and rotting.
CSHADES is offline   Reply With Quote
Old 12-16-2015, 09:05 PM   #15
zaccaglin
zaccaglin's Avatar
I plan to dynamat the floors in the future along with oem carpet insulation and padding. When I redid the headlined I did add styrofoam insulation sheets between it and the roof. That helped a lot with road noise, rain noise and cab temps.
Zaccaglin
1998 Chevrolet C1500 Ext. Cab 350
Former Rig:
1985 Chevrolet K20 Suburban 6.2L Detroit/TH400/NP208
zaccaglin is offline   Reply With Quote
