Old 12-14-2015, 09:40 AM   #1
DT1
DT1's Avatar
Getting One Today
I'm excited to pick up my new pickup today after work. It's a LWB 72 C10 with 350/350, Air, PS, PB and Wood Bed. I'll post pics as soon as it arrives.
I do, however have one simple question for you guys. I thought I could tell the difference between 71 and 72 but the owner says the title states 72 I haven't seen the title. With the exception of the color, it looks identical to my 71. There is what looks like a home made SPID so I don't think that will be much help. How can I tell the difference between the model years?
DT1 is offline   Reply With Quote
Old 12-14-2015, 09:50 AM   #2
68Gold/white
Re: Getting One Today
One way. is a lone screw in the door panel below the wing window. It was in 72's only, helps w/ rattle....
68Gold/white is offline   Reply With Quote
Old 12-14-2015, 09:52 AM   #3
engineer_gregh
engineer_gregh's Avatar
Easiest way is by the VIN. A 72 will begin with CCE142 and a 71 will begin with CE141. Physical differences are interior door panels and rearview mirror.
1971 Longbed BB Cheyenne Super
1972 Longbed SB Cheyenne Super
1972 Longbed Highlander Custom Deluxe
1975 K5 4x4 full convertible
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=645165
Greg Smyrna TN
engineer_gregh is offline   Reply With Quote
Old 12-14-2015, 10:07 AM   #4
jocko
jocko's Avatar
71-only grille surround had a black perimeter stripe whereas 72 did not. Not a great indicator though as they are interchangeable and the stripe usually wears off quite a bit from the 71 grille surrounds. All aftermarket are 72-type with no black perimeter striping on the grille surround. Other than the VIN (the metal one on the drivers side door opening - and, all that REALLY matters...), the door things mentioned above (screw, panels) and mirror are the best indicators. But, doors are interchangeable also... Mirrors can change too, but when going from 71 to 72 style, I believe some holes are left in the 71 cab (good clue). VIN tags are not (or, at least, SHOULD not be). When you pick it up - I'd make sure the VINS all match (SPID (fake or not), metal tag, and frame (not as important to me)) - just so you can be comfortable or, at least, aware of the originality.
Old 12-14-2015, 11:21 AM   #5
73737373
Check the rivets on the metal tag in the driver side doorwell. They should be a "star" shaped, not perfectly round....although that's not a difference between year models, it will tell you if that plate has been removed and been reattached, quite possibly, from another truck.
73737373 is offline   Reply With Quote
Old 12-14-2015, 12:25 PM   #6
As mentioned, a '71 VIN will start CE1 and a '72 VIN will start CCE1. That is absolute. Parts can be changed or even early/late production carry-overs
Old 12-14-2015, 12:51 PM   #7
DT1
DT1's Avatar
Thanks Guys,
I didn't realize the two model years were so similar.
Old 12-14-2015, 03:37 PM   #8
cypressbog
Go Pack Go!
71 cabs are the only year where there's a raised pad above the windshield to mount the rear view mirror.
cypressbog is offline   Reply With Quote
Old 12-14-2015, 03:49 PM   #9
BrianG
BrianG's Avatar
Correct, The prior years did not have this pad. 71 and prior had the rear view mirror on the cab (special pad mount 71 only), while 72 had the mirror mounted to the windshield.
BrianG is offline   Reply With Quote
Old 12-14-2015, 07:26 PM   #10
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
I don't want to change up the thread but are you talking about the black around the headline door area like in pic.
1992 K1500 GMC Suburban
" In the end, we only regret the chances we didnt take "
" Time is the only currency we spend without knowing the balance, use it wisely ." ..
Old 12-14-2015, 09:19 PM   #11
swamp rat
swamp rat's Avatar
My 72 has the black stripe..... All origional truck.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 12-14-2015, 09:21 PM   #12
Gimme Jimmy
The '72 was the first year that required a vapor canister.
Gimme Jimmy is offline   Reply With Quote
Old 12-15-2015, 09:39 AM   #13
DT1
DT1's Avatar
OK, it's definitely a 72. I drove it the 20 miles to get home last night with no issues. It needs an A/C compressor, condenser and drier but it runs and idles well. The only issue is that some PO has sprayed it with bed liner. The bed is wood and the liner is only on the sides and tailgate. Anyone know how to get the stuff off?
Pics to follow if it's light enough when I get home from work today.
Old 12-15-2015, 09:47 AM   #14
70cst
70cst's Avatar
Hey DT1 ...
Can't wait for pics.
Bed liner removal - good question - I'm signed on
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 12-24-2015, 06:09 PM   #15
DT1
DT1's Avatar
Well, it took some time but I finally got around to taking some pictures.
Old 12-24-2015, 07:45 PM   #16
70cst
70cst's Avatar
That indeed is a keeper
Old 12-25-2015, 02:49 AM   #17
kwmech
I like the mismatched valve covers, and there is the always present rubber fuel line with the 99c plastic filter
Old 12-25-2015, 11:14 AM   #18
trac209
Nice find!
trac209 is offline   Reply With Quote
Old 12-25-2015, 11:23 AM   #19
DT1
DT1's Avatar
Yes Yes...Much to do...The woods are lovely, dark and deep. But I have promises to keep, And miles to go before I sleep, And miles to go before I sleep.
Old 12-25-2015, 12:12 PM   #20
doo142
doo142's Avatar
Nice truck!! Fixing that little stuff is part of the fun!! Don't know if you know it but you are a poet !! Peace!
doo142 is offline   Reply With Quote
Old 12-25-2015, 12:28 PM   #21
flashed
Very nice truck you have there.
flashed is offline   Reply With Quote
Old 12-28-2015, 09:38 AM   #22
73737373
Now the ochre one will have someone to talk to, "What assembly plant were you built at?" "Where were you sold?" "Do you have your original engine?" Yeah, I know, pretty odd, but I hear my trucks whispering all the time.
Old 12-28-2015, 11:23 AM   #23
joeydurango
joeydurango's Avatar
Nice truck.
I want to see more of the Ochre Cheyenne. Thinking about one of those right now.
Frost, isn't it? Or at least Over The Rhine lyrics quoting Frost? Good taste.
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER
1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD
1976 Trans Am | 400/4-spd | SOLD
1976 Trans Am | 455/4-spd | TOTALED
joeydurango is offline   Reply With Quote
Old 12-28-2015, 01:03 PM   #24
DT1
DT1's Avatar
Originally Posted by joeydurango View Post
Nice truck.
Yes, Frost. Used in the movie Telefon with Charles Bronson.
Some pics of the Ochre Ogar...
Old 12-28-2015, 01:09 PM   #25
73737373
Very pretty. Of all of them ever made, LWB Ochre/white is my favorite. Ochre one talks to the red one all the time......
