Old 12-15-2015, 01:02 PM   #1
bobrust
Any thoughts on how low?
I have a 1987 Chevy shorty, I have lowered it 3" in front with springs. I am thinking about 3" more with spindles. Will this be to low to drive? I did a rear end flip as well, back is lower than front as of now. Any thoughts?
bobrust is offline   Reply With Quote
Old 12-15-2015, 02:45 PM   #2
SCOTI
SCOTI's Avatar
Re: Any thoughts on how low?
They can be driven @ that height but will make contact with the road. How fast you're going & how solid the irregularity in the road surface will determine the extent (if any) of damage done.
For daily driving, you'll want the front x-member farther from the road surface which means more extensive mods.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 12-15-2015, 10:09 PM   #3
bbbc10
Diggin The SquareLife
go with 2.5 western chassis spindles.....6" would be to low
bbbc10 is offline   Reply With Quote
Old 12-16-2015, 02:12 PM   #4
tinydb84
tinydb84's Avatar
How tall of a tire are you running? You might be fine with ground clearance on a 30 inch tire (but will have fender clearance issues) vs a 26 inch tire.
David
Instagram: myfabguy
Old 12-18-2015, 11:30 PM   #5
broey
Square
broey's Avatar
x2 on what SCOTI said, if you want to go that low on a daily you will really want to look into raising the front crossmember. PB is your best bet.
Squarebody Syndicate
broey is offline   Reply With Quote
Old 12-19-2015, 02:08 AM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I have a different truck, so its not a direct comparison, but I drive mine on a ~4.5/6" drop and never ran into much of an issue bottoming out. I wouldn't even consider it all that low with a mid-profile 15" tire.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 12-19-2015, 02:38 AM   #7
SCOTI
SCOTI's Avatar
4.5" front drop is mild. 6" is trouble for the daily depending on where you reside ( how smooth/nice the roads are).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
