Old 09-18-2003, 12:56 PM   #1
BigRed
Throttle Cable Adjustment??
Is it possible to adjust a throttle cable?
I can floor my accelerator pedal and it doesn't extend my throttle linkage all the way back. I can still push it back by hand about 1/2 inch.
Scott Shelbourne
BigRed is offline   Reply With Quote
Old 09-18-2003, 05:21 PM   #2
SCOTI
SCOTI's Avatar
If there was a way to verify the correct cable length for your application vs. what is actually installed on the truck, that might be worth a try. Case in point: my old 78 camino had 1/2 a V8 w/a 2 barrel & @ some point in its life someone swapped the throttle cable for a Q-jet 4 barrel cable. It was too long & I couldn't get full throttle (not that your missing anything @ full throttle w/ 1/2 a V8).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 09-18-2003, 09:36 PM   #3
BigRed
Well, not sure if I can really tell if this is the correct cable for the application. Guess about all I can do is replace it if it's not adjustable.
Scott Shelbourne
Old 09-18-2003, 09:57 PM   #4
1FaastC10
1FaastC10's Avatar
Scoti, was that 4 cylinder a factory option? i've never seen one with a 4 in it
1FaastC10 is offline   Reply With Quote
Old 09-18-2003, 10:38 PM   #5
SCOTI
SCOTI's Avatar
No, not a 4cyl.... 1/2 a V8. The baddest ass V8 GM ever had the brilliance(?) to build.... the mighty 267 (sounds of thunder all around).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-18-2003, 11:11 PM   #6
swervin ervin
You get what you pay for
swervin ervin's Avatar
Scott,
there are no adjustments. You will have to replace the cable. Make sure you get one specific for your ride.
Oh, forgot to ask, you did make sure there is nothing under the pedal, right?
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 09-18-2003, 11:13 PM   #7
BigRed
Originally posted by swervin ervin
Scott,
Ok, thanks Mike.
LOL Nope, actually checked the obvious first this time.
Scott Shelbourne
