Aftermarket Flexplate cover
I'm wanting to buy an aftermarket TH350 flexplate cover as my stocker is getting pretty worn out. finding a number of different ones on Summett, Jegs, Flea bay and amazon but also reading in the reviews that some have fitment issues.
If you have bought an aftermarket unit for a TH350 could you tell me which one and if you were happy with it or what modifications you had to do to make it fit?
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
Re: Aftermarket Flexplate cover
I wish I could help on this, but I've bought 2 that I could not get to fit. I'm hoping someone has an answer for us!
Bump, anyone else?
Can you tell me what brand or part numbers you bought so i know to steer away from them??
I can't help with part numbers unfortunately. The first one I bought was a chrome aftermarket cover that I bought from a guy on Craigslist. He said he bought it from Summit and claimed he had it installed on his 69 C10. He had trimmed it near the starter, but I could not get the holes to line up, and the flywheel contacted the inside of the cover.
The 2nd one I bought from a member parting out a truck here, on the parts board. It was supposedly an OE factory steel piece (it did appear to be), but I still had the same issue with holes not lining up and it contacting flywheel. Since then I've been afraid to buy another one lol!! I must be doing something wrong, or maybe I keep getting covers intended for the TH400? |
![]() Join Date: Dec 2012
I'd like to know too. My truck came without one
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
if holes don't line up I use what is called an electric drill and make appropriate adjustments then if it's hittin somewhere I use what is called a dermal tool to make it not hit anything
Well smart ass i was reading reviews about how some of these are twisted badly coming out of the hydropress and no matter how much they tried to straighten then they ended up hitting the flex plate, just wanting to avoid that and not have to do a return ship, is that too much to ask? i really would not want to use a dremel ( NOT DERMAL ) to grind a hole in the body of the thing to clear flex plate teeth, kinda defeats the purpose.
well since you don't have the skill to fabricate a fix it might b cost effective for you to hire a professional to do it fer you
Shots fired, shots fired!! Everyone stand down!! Lol
We're just trying to find out if there's a piece that is a direct replacement, when there's a known, common issue with the replacement parts not fitting properly. Since I've had no luck with the ones I've picked up, I've figured my only options are to modify and shim to get one on, or just go without one. Would be nice to hear from anyone who's found one that fits correctly (if such a one exists...) |
Yet again you let your ignorance fly, go get a life
I had the same problem as TexasLS1 with this one from Summit...no good.
SUM-G3883B
72 Cheyenne SWB C10 (daily driver) (Super fake cause I just love the glovebox emblem) 70 Camaro RS (frame-off in pieces) 70 Camaro RS (daily driver backup) 69 Custom LWB C10 (son now drives) |
#13 |
Interesting, Very Interesting...
#14 |
Thanks!
#15 |
Do you think they are still available through a GM dealer? Mine is the thick plastic one and fits great. I assume it is OEM, but maybe not. Just thinking the TH350 was used on a lot of vehicles and the dealer still might carry them.
![]() Edit: I checked RockAuto....nada.
1970 C10 Short Stepper with 71/72 front clip….gave to my son in Goodyear AZ. Last edited by BugzC10; 01-02-2016 at 10:54 AM. |
#16 |
I don't have any experience with the aftermarket choices, I personally would just go grab a factory piece from the wrecking yard.
#17 |
People know me
I just went up to my local transmission shop and bought a new locking dipstick, tube, GM cover and a shifter lever for my TH350 the cover fit no problems at all with the 164 tooth flexplate and bolted up no modifications
![]() Google of the factory part number gm 14038632 shows it availible here http://www.gmpartsdirect.com/oe-gm/14038632
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels 1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels |
#18 |
http://www.gmpartsdirect.com/oe-gm/14038632[/QUOTE] That part number is also available on Amazon and eBay.
1970 C10 Short Stepper with 71/72 front clip….gave to my son in Goodyear AZ. |
#19 | |
#20 | |
Thanks Bugz, ordered thru Flea bay.
#21 | |
I think anyone who can grab a wrench has the skill to install a flex-plate cover, if they've never put a part on in their life. There is only one flex-plate cover on a vehicle and only one TH350 case. There is no reason a flex-plate cover made for a TH350 shouldn't fit on all TH350s in any vehicle. GM ones do. The issue here is the aftermarket part is crap and the tool required to fix it is a trash can
#22 | |
If ya read my posts you will see i just wanted to buy a possibly better replacement cover after reading reviews that some of the aftermarket stuff was crap, that and figuring a stock replacement was no longer available.. The only reason one stock GM TH350 cover may not work with another GM TH350 is when ya got a standard case and a K case. Knowing now that an original GM part number is available for the cover its a non issue. As i just posted i went ahead and ordered the number that was just posted. End of discussion.
#23 |
I read the entire thread. Who pissed in your Cheerios? You should know that when someone quotes a post, then posts a reply, it means they are responding to that post. Oh wait, you just quoted me because you were responding to me, so you already knew that. Just Chill out then...sheesh! BTW, are you saying you just grab and turn the extension and socket with your hand or do you fasten that to a WRENCH?
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 01-05-2016 at 08:08 PM. |
#24 |
Swamp Rat or bigbadchev72- How does it fit?
| Bookmarks |
