Inner fender removal.
Can someone post some info on how to remove the front inner fenders (engine compartment), on an 87 Suburban please?
Guessing you put have to remove the fenders and can't get them out from the bottom with the tires off.
![]() 1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824 |
Next!
![]() Join Date: Jan 2003
Re: Inner fender removal.
Removing inner fenders, done it many times, never had to remove the tires (does make it easier though) and certainly you don't need to remove the fenders.
Just finished replacing them on my K30 dump. Tires and fenders stayed on. Quite an easy swap. Just remove everything attached to them first, for example, battery trays, brackets, etc. The biggest issue is the speed nut will usually break off. The bolts down by the radiator support under the battery can also be an issue and usually break off. Nothing a drill and tap can't fix for re installation. Just take your time and don't force anything.
86 K30 CUCV M1028A1 86 K30 CUCV M1028a2 dually 86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump More square bodies and CUCVs than I care to admit to 2020 Silverado K3500HD Work truck |
#3 | |
#4 | |
There are a series of 1/2" bolts and a couple 9/16th's along the outer edge where it mates to the fender, radiator support and 1 through the bottom of the battery tray IIRC. There are none facing toward the engine - think semi-circle. Take the bolts off and the inner fender comes out.
Folks that throw dirt on you aren't always trying to hurt you, and folks that pull you out of a jam aren't always trying to help you. |
| Bookmarks |
