Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 01-02-2016, 10:51 AM   #1
63frankintruck
WTB rear differential for 63 C10
Looking for a rear diff complete 5 X 5 preferably w/ posi.
Anyone got one laying around? If not I will proceede with converting my current 6 lug over and adding a posi or Tru track
63frankintruck is offline   Reply With Quote
Old 01-02-2016, 04:43 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: WTB rear differential for 63 C10
If your not successful finding one - I have a 64 6 lug posi and am upgrading to 5 lug posi using this guys components: http://www.quickperformance.com/GM-1...-12T_c_54.html
Old 01-02-2016, 07:48 PM   #3
63frankintruck
Interesting, are you planning on doing the upgrade yourself?
Old 01-03-2016, 09:18 AM   #4
The Rocknrod
Moderator
Local shop in China Spring, TX will do the work. If it were a 9" I would.
Old 01-03-2016, 09:23 AM   #5
63frankintruck
Ok, sorry for all questions, but do you have to purchase 5 lug drums when doing this conversion or can the 6 lug be redrilled to match new axles?
Old 01-04-2016, 12:03 AM   #6
Captainfab
60-66 Nut
You can redrill your original drums. However since the hub register on the new axles will be aprox 1/2" smaller in diameter, I would recommend new 5 lug drums.
Old 01-04-2016, 07:27 PM   #7
63frankintruck
Ok, good to know. Would these drums from a 73 through 87 fit with the 63 conversion as long as they are from a 12 bolt?
Old 01-05-2016, 12:43 AM   #8
Captainfab
60-66 Nut
As long as they are for the 2" wide shoes and not the 2-3/4" wide shoes, yes they will work.
Old 01-13-2016, 08:46 AM   #9
63frankintruck
Found a rear from Jimmy on CL
Would this work?
Axle is from a 72 Jimmy 4x4. Axle has new wheel cylinders, e-brake cables, and all break hardware. It is an open carrier with 3.73 ratio. I changed to a 14 bolt so the axle needs a new home.
Any foreseen problems for using in 63? Brake size, differential width?
Old 01-13-2016, 08:31 PM   #10
63frankintruck
[QUOTE=63frankintruck;7445808]Found a rear from Jimmy on CL
Would this work?
Any foreseen problems for using in 63? Brake size, differential width?[/QUOTE
I had the seller measure today and this was his findings:
Brake shoes are 11" x2"
Backing plate tp backing plate is 56"
I did not get a chance to measure my differential today and now its too dark outside. (So I'm not sure if this rear for sale will fit or not) :dum
Old 01-14-2016, 12:34 AM   #11
Captainfab
60-66 Nut
A '72 Jimmy 4x4 will have leaf springs as well as be 6 lug plus it is an open carrier. I thought you wanted a posi and 5 lug? With this differential you will have to cut off the leaf spring pads and weld on trailing arm mounts as well as the panhard bar mount from your '63 12 bolt. Measuring backing plate to backing plate is a highly inaccurate way to measure the width of a differential. You really should be measuring WMS to WMS (Wheel Mounting Surface). That is the dimension that matters. That '72 12 bolt should be 1.5" wider than your '63 12 bolt
Old 01-14-2016, 07:05 AM   #12
63frankintruck
Thank you sooo much for the help! Saved me a lot of Agravation��
