Old 01-14-2016, 09:24 PM   #1
Apachemike
Apachemike's Avatar
Anyone running a carbed LS 5.3 or 5.7??
Any advantage to this? Found a deal on a controller and intake and the LS's are becoming cheaper but don't know about without the EFI
Apachemike is offline   Reply With Quote
Old 01-14-2016, 10:28 PM   #2
Flysocal
Re: Anyone running a carbed LS 5.3 or 5.7??
I have an LS1 and thought about it. Decided to stick with efi. It's going in a 49.
Flysocal is offline   Reply With Quote
Old 01-14-2016, 10:46 PM   #3
iowaboynca
iowaboynca's Avatar
http://67-72chevytrucks.com/vboard/s....php?p=7277569
Check this out. I found it informative.
Build: "1950" GMC -Charlotte
iowaboynca is offline   Reply With Quote
Old 01-14-2016, 11:31 PM   #4
Chris.
Pretty sure it ends up costing more to put a carb on it than to set it up to run the efi you can get the wire harness cut down to the bare minimum you need and computer flashed for like $400 from 150tunes.com and a fuel pump for like $200
Chris. is offline   Reply With Quote
Old 01-15-2016, 09:47 AM   #5
Apachemike
Apachemike's Avatar
Thanks Iowaboy! That was a great writeup he did. I would not even be considering this if I didn't have a line on a low mileage 5.3 ($500) and and msd LS1 controller kit and manifold ($400) If this will bolt directly to my 700r4 I think it's the way I will go
Old 01-15-2016, 10:24 PM   #6
iowaboynca
iowaboynca's Avatar
Glad I could I help. Make sure to check the LSx swap section too. (Where I got the link) That area has plenty of info too.
Old 01-16-2016, 07:17 PM   #7
LEEVON
Moderator
LEEVON's Avatar
Easy-peasy. Just add fuel and go. Check out my "Popeye" thread.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 01-16-2016, 10:50 PM   #8
mr48chev
mr48chev's Avatar
Not to be controversial but I'd think you would loose a large percentage of the total performance of the LS engine by going to a carb Plus from what I can see it's going to take a bit over 1000 bones to do the conversion. That includes the intake, timing control module and then add a valley plate on top of that.
My ongoing truck projects:
Old 01-16-2016, 11:09 PM   #9
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
I was reading a comparison that Hot Rod Magazine or one of those magazines did and they said the Carb actually out performed the FI, but it was at very high RPM's. I have been looking at all the LS options for my Burb and all the reading has made my eyes hurt.....
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 01-16-2016, 11:21 PM   #10
71meangreenc10
Yes,
A 700R4 will bolt to a LS, but it you wont use all the mounting bolts and you need this kit. http://www.speedwaymotors.com/LS1-En...DisplayId=5070 There is also a kit for the TV cable mounting that Holley sells. Dont have that link at the moment.
Smitty
71 C30 Wrecker
Old 01-16-2016, 11:54 PM   #11
iowaboynca
iowaboynca's Avatar
Mr48chev -Not controversial at all. I'm no expert, so what i'm going to say is just based upon my own research because i'm going down this route.
I wouldn't say its performance (i mean power/HP) but more driveability, i.e. carb vs. FI. And in that case I would say that would as true as having to dial in any carb.
Financials...whew...you aren't kidding. In my case, i got a pretty good deal on a '02 5.3L long block out of a tahoe. But I needed the controller and the intake and i'm looking at the aftermarket TBI injection from Holley, FAST, edelbrock, etc. and that's probably going to come in at $2k. All told everything being even i'm a little north of $3k for powerplant. So a SBC long block with a decent top end vs. building up the LS...I felt it was a bit of a wash.
Now if I was to do it over, i'd LOVE to find a 5.3L w/the harness, ecm, and transmission out of a wreck but not on this build.
But as I began, your right, its not the most economical and not being contraversial at all. I figure this plus the suspension so far are the biggest cash sinks and needed some planning.
Old 01-17-2016, 10:04 AM   #12
Advanced Design
Advanced Design's Avatar
Iowa....before buying FAST, Holley etc., check out FItech. Several guys on here are installing with good results and the system is very reasonably priced. Here is one install as an overview. http://67-72chevytrucks.com/vboard/s...d.php?t=653268
I haven't done the math for carb vs factory efi cost on an LS. Is there that much savings? My personal preferance is the solid driveability of the fuel injection.
Advanced Design is offline   Reply With Quote
Old 01-17-2016, 01:01 PM   #13
iowaboynca
iowaboynca's Avatar
AD- Thanks I did look at the FI tech system and will keep and I on that system. In fact I think it made Holley a little nervous as it looks like they announced a similar system at SEMA.
Apache Mike- No to bogart your thread I know you asked about a carb but if you would think about the FI we're talking about you also would need to change out your fuel delivery system as well ( pump, filters, returns, tank etc) which also adds cost. Something to think about. At the end of the day, as history has proven, with enough time, money and effort, we can send a man to the moon! It just depends if its in your time money and effort.
Old 01-17-2016, 01:31 PM   #14
Apachemike
Apachemike's Avatar
Iowaboy: Bogart away! It's all more information that is usable. Can't complain about thar
Mr 48Chev I wouldn't consider this if I didn't have a line on a controller witth intake for around $450 (seller is at $450, I offered $400) Intake , controller, timing chips, wiring. But i know there is more to the swap than just drop it in and go
Old 01-17-2016, 09:47 PM   #15
Coach529
Coach529's Avatar
Some great info here. I have been casually looking into an LS at some point on a project, but never considered running one without EFI.
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
