Old 01-26-2016, 11:35 AM   #1
v30crewcab
v30crewcab's Avatar
Power lock wiring
looking to add power locks to my crewcab, I'm curious where the wires go thru the cab from the door on a factory setup. I see the holes you drill to put in the loom piece between the door and cab, but where do the wires come out from there? its double wall behind the kick panel. is there a factory hole behind the dash they come out of? pics would be awesome. thanks
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 01-26-2016, 11:41 AM   #2
gmachinz
Re: Power lock wiring
Yes-there is a hole just above each kick panel-it accesses a 3" or so cavity before going out through the second hole which is sealed up with the accordion boot.
gmachinz is offline   Reply With Quote
Old 01-26-2016, 11:44 AM   #3
gmachinz
If you need simply a power lock only harness I have them in stock for a crew cab. I can also supply lock switches and possibly door jamb accordion boots if you need them. PM for details or, if you have a complete factory setup in good shape then never mind.....lol
Old 01-26-2016, 11:49 AM   #4
gmachinz
And behind the b-pillar trim there is a 1" hole just above the floor seam where the rear door wiring travels through-no grommet either, just a smooth machine punched hole before extending into each door via a boot.
Old 01-26-2016, 06:26 PM   #5
v30crewcab
v30crewcab's Avatar
what about a pic of where the door lock button goes in the door panel. trying to decide if I want to cut my panels or just put a switch in the console.
71 longbed 5.3 4l80
Old 01-26-2016, 09:02 PM   #6
gmachinz
Actually, if you simply wanted a single switch in the console, the wiring would be a little easier for you to run AND, no holes in your door panels.
Old 01-26-2016, 10:18 PM   #7
v30crewcab
v30crewcab's Avatar
so does the wiring go thru the same hole that the door light switch goes thru? the only other hole is almost at the top of the dash and appears to not go down at all.
71 longbed 5.3 4l80
Old 01-26-2016, 10:34 PM   #8
gmachinz
On the front doors there is a flat area on the cab between the hinges-that is where the hole needs to go for the wires to come in, but then directly across from it on the kickpanel side you need to drill another hole-there is about a 3" gap between the two.
Old 01-26-2016, 10:35 PM   #9
gmachinz
My harnesses come with new cab grommets so you can use them as a guide as to what size hole to drill but I believe its 1.5"
Old 01-26-2016, 10:40 PM   #10
v30crewcab
v30crewcab's Avatar
ok so the factory harness has another hole drilled on the inside as well as the outer doorjamb hole then.
71 longbed 5.3 4l80
Old 01-26-2016, 10:56 PM   #11
gmachinz
Correct. Both holes are machine punched from the factory-when I add accessory holes like that I always use a reamer to smooth the edges-it helps to reduce wire chaffing. I so use a kevlar type abrasion sleeving in that very area as extra protection. There are little things like that which are better than GM designed for.
